Need Help on Heads on Gen 5 454's
Pirate of the Chesapeake
Neighbor has a pair of stock 330-340 inboards out of his sea ray both standard rotation.Bought a offshore boat with no engines .Wants to use these,>reason for removing them was one had a blown head gasket and he re-powered with fuel injected engines.Now he is removing the heads and was asking if a head and intake manifold change would give him a little more HP.Does not want to get into the lower end.Has small ovel port heads on it now.Just want a little more than 340 HP Just a river boat .Wants to use the engines because they were well taken care of and are closed cooling system .Any thoughts or help would be helpful. Thanks JOHN SR
grab rectangle ports, dual plane intake, and cam for 46-4700 rpm, should be fine... bottom ends are not the strongest but I dont see the power being enough to worry about anything.
Ihave seen good success with aluminum oval ports, not sure what budget is, I was thinking cheap budget, Gellner was offering a nice Brodix head already set up for Marine with Inconel, maybe give him a call see if hes still doing it...Dean told me when I was looking at doing my 454, now I went to 540 so thats out the window...
https://www.google.com/url?sa=t&rct=...79908130,d.cGU
Hmm, I thought I'd replied but I guess it did'nt show up.
Mysuggestion is to change to Dart Iron Eagle heads, roller cam, Dart intake and Holley 750. Yoiu will make 450+ hp cheap and relable.
Wannabe
Wannabe
Gm 781 ovals make good power. I had a 330 bottom end. Used 781 ovals, edelbrock performer, comp extreme marine flat tappet, 830 holley, scorpion roller rockers, and imco powerflow exhaust. Made a solid 450hp at 5000 and it ran awesome for years until I overheated it not realizing my tilt switch wasn't working running in shallow water.
