Need an Anchor
I use a 2 foot spike works awsom but you have to be in shallow water so you can ush it into the bottom , means you have to get wet. But I'm a sand bar boater so it matters what n where you're anchoring good luck.
I have a Fortress with 8' of stainless chain. It has NEVER let go. Sometimes I even have a hard time trying to pull it out. Looking to get a 2nd one for this coming season. Wouldn't even consider anything else.
I use the "small" box anchor. It regularly holds a 33' AT, 33' scarab AVS, a 283 checkmate and a 303 checkmate with no problem in a slight breeze. comes with storage bag and is collapsible. I use to have a big galvanized fluke anchor and it took up too much space and couldn't hold a candle to the holding power of the box. Wouldn't even consider anything else on the market after using one of these.
https://www.slideanchor.com/slide-an...ations_137.htm
