Choosing Valve Covers >
Old 11-28-2014 | 07:37 AM
Default Choosing Valve Covers
I am shopping for valve covers for my Gen6 502. Roller Rockers and lightning headers. Has anyone used automotive covers in a marine application. Or can anyone turn me on to a place that has some marine covers.
hadleycat is offline
Old 11-28-2014 | 07:50 AM
you can use the factory alum covers(they seal the best with the O-ring seal) by removing the oil deflectors from them and grinding a couple of rockers, to go to tall ones may not be a option with the procharger, won't clear on mine at all, but if it will you need the marine angled ones to give you room to get to the bolts as headers are close..
ezstriper is offline
Old 11-28-2014 | 07:56 AM
Thanks, forgot about the stupid Procharger being in the way. I like the Teague Marine tall covers. I may have to relocate my shift interrupt also.
Old 11-28-2014 | 10:17 PM
The tall one's just need a little love. You can see how close the blower sits to the rockers, it is definitely tight. The two piece Eickert ones fit no problem though. I don't know why half my pictures end up sideways now..
[ATTACH=CONFIG]533394[/ATTACH][ATTACH=CONFIG]533395[/ATTACH][ATTACH=CONFIG]533396[/ATTACH][ATTACH=CONFIG]533397[/ATTACH][ATTACH=CONFIG]533398[/ATTACH]
Attached Thumbnails Choosing Valve Covers-img_2125.jpg   Choosing Valve Covers-img_2130.jpg   Choosing Valve Covers-img_2143.jpg
HaxbySpeed is offline
Old 11-28-2014 | 10:33 PM
I tried 4 sets of aftermarket, don't waste your time they will not work. Went with hardin marine tall marine. No procharger just rollers and stainless marine exhaust.
GLENAMY 242SS is offline
Old 11-28-2014 | 11:27 PM
Thanks guys, I would also like to go with the tall breathers to eliminate the breather hoses to my intake. Will these work well on a Procharged motor ?
Old 11-29-2014 | 09:09 AM
wanted to run a stud girdle on mine after talking to Bob M. even bought one...then looked at the valve cover deal...removing the bell would help a bunch but did not like the idea of nothing over the intake, I talked to articfriends and he made it work by cutting the bell up and using double or extra thick gaskets and factory covers...I have not tried yet...
Old 11-29-2014 | 05:20 PM
I have the tall Teague covers. Had to grind a groove on the front bolt boss on the throttle body side of the mpi motor. The throttle linkage had interferrence and wouldnt open past 1/3 throttle.
Gimme Fuel is offline
Old 11-29-2014 | 05:26 PM
14 apache's Avatar
How do the pro chargers hold up gears bearings? How much boost and power? Thanks
14 apache is offline
Old 08-05-2015 | 07:12 AM
Used the Teague tall covers. to my surprise they cleared the M3 Procharger by about 1/32 of an inch [ATTACH=CONFIG]543887[/ATTACH][ATTACH=CONFIG]543888[/ATTACH]
Attached Thumbnails Choosing Valve Covers-037.jpg   Choosing Valve Covers-038.jpg
