Calling all mechanics >
Old 12-03-2014 | 05:55 PM
found it,,, http://www.offshoreonly.com/forums/s...ed-prices.html
FIXX is offline
Old 12-08-2014 | 02:13 PM
Originally Posted by Bondo
Ayuh,.... Then freezin' seems to be 'bout the most remote of possibilities,....
Do as airjunky says,...
Drain the coolin' system, block it off/ isolate it, 'n plumb in a pressure gauge, 'n air fittin' to pressurize it,...
It oughta hold 15 psi pretty much Forever,....
If it don't,... follow the sound of the escapin' air,...
+1
If it were the exhaust manifolds leaking that much water it would have hydro-locked, at the very least you would see excessive moisture on the plugs. I have a crossover setup with a thermostat and boat in 34 degree water and have never had my oil look milky, I'm betting on intake or head gaskets.
ThisIsLivin is offline
Old 12-10-2014 | 09:50 PM
first thing i would do is remove the exhaust manifolds and pressure check them.real good chance this is the culprit.
mike tkach is offline
Old 12-11-2014 | 09:33 AM
Bad manifolds!
PROTOTYPE28 is offline
Old 12-11-2014 | 09:50 AM
obnoxus's Avatar
Charter Member #1171
Yup,,,,,I agree,,,, pull the plugs and look for a wet/rusty one leading to exhaust manifold,,,,, if not Id be pulling the intake next
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 12-11-2014 | 10:22 AM
Can also have a leaking oil cooler. Just another thing to look into
sonic700 is offline
Old 12-11-2014 | 10:41 AM
Knot 4 Me's Avatar
sicktrickrick I'm local to you so let me know if you need anything. I was thinking along the lines of Griff at first but appears to be more than just condensation. Your boat might have been talked about to me a couple weeks ago at a local bar by the owner. She was asking me about size limits on Clinton Lake.
Knot 4 Me is offline
