-   -   Favorite BBC Rod Thread (https://www.offshoreonly.com/forums/general-q/320770-favorite-bbc-rod-thread.html)
Full Force 12-10-2014 11:37 AM
Originally Posted by mike tkach (Post 4232785)
i don,t think he means bent because he stated that detonation causes the piston to TWIST.back in my racing days i met a lot of nitrous guys who would push it past the limit.serious detonation can ruin an engine in less than a second.one time a guy took the head off and it and what was left of the piston looked like someone was in there with a torch but no TWISTED rod.
Thats what I mean, I seen things detonate to nothing and the rod was fine.... ANYTHING is possible though, just because we didn't see it don't mean it can't happen right? HAHA
MER Performance 12-10-2014 12:24 PM
Originally Posted by Full Force (Post 4232580)
Amazes me... I am not re-using any of it in my new builds, all new even blocks...cranks were even hitting bottom of pistons!!! how do you not feel or see that when ASSEMBLING?
But I didnt twist a rod!!! LOL
[ATTACH=CONFIG]534062[/ATTACH][ATTACH=CONFIG]534063[/ATTACH]
That was surely a "rookie build" if those were 6.385 rods, trying to figure how the counter weight, scrubbed the piston. What is the compression height of the piston ? 540 CID build; correct ? Using a 6.385 counter weighted crank, with a 6.135 rod and trying to have a taller C.H. on piston, to bring piston up to -.025 D.H.
MER Performance 12-10-2014 12:33 PM
142985 547 4.530 4.250 6.385 9.780 1.270
part # CID Bore Stroke Rod Deck C.H.
Whats the measurement from center of crank to O.D of counter weight ?
Full Force 12-10-2014 12:38 PM
Honestly I still have no clue what this guy did...what I have found out so far (hence starting with all new parts and none of this used again)
1-crank is 4.375 stroke
2-rods are 6.385 never measured them but the paperwork said they were that Dave gave me.
3-pistons say for 540 kit
the pistons were at least .020 out of the hole, blocks 4.5030
I have no clue how you can build the rotating assembly and have it hit piston skirts, how the hell did he rotate it?
this is the guy, look at his garage if this works, thats enough to tell me bad news... I have no idea why my buddy went to him...
https://www.facebook.com/profile.php...774194&fref=ts
Full Force 12-10-2014 12:43 PM
1 Attachment(s)
I am not sure..
.[ATTACH=CONFIG]534094[/ATTACH]
Black Baja 12-10-2014 12:55 PM
Originally Posted by Knot 4 Me (Post 4232733)
You'd think it would just bust the wrist pin out of the skirt as opposed to twisting the rod. This is the only way I've seen them "twisted". Pics would be cool!
That's not bent or twisted. It's slightly curved.
stimleck 12-10-2014 01:00 PM
But it looks so easy to build a motor on Powerblock tv!
Knot 4 Me 12-10-2014 01:00 PM
Lol! Curved road ahead! :flag:
MER Performance 12-10-2014 01:52 PM
Running a 4.375 stroke, 6.385 rod CH of 1.270 would take you .042 out of the hole. If you had a .050 thick gasket the piston would rock and hit. Someone machined pistons down, either a custom piston would be needed or use a 6.535 rod with custom piston having a 1.077 C.H. I'm pretty sure the ring stack would work being its a NA build. I have no idea how you, can swing that piston and rod length around that counter weight unless, you machined down counter weights.
Not the best combination for a 4.375 crank in a 9.800 deck block
the deep 12-10-2014 01:55 PM
That's what happens when you get old right SB . :picard1: http://www.offshoreonly.com/forums/a...d-bent-rod.jpg
MER Performance 12-10-2014 02:20 PM
I was trying to digest; Full Forces, build here. I just finished off 10 oz of magnesium citrate, lets see what happens.
Full Force 12-10-2014 02:30 PM
Oh the pistons were ever so slightly touching the heads... Inwill post pics when I get home same as his hack grinding on crank I would assume from hitting pistons... I never seen such a cluster fuk build before I wish I would have never bought the scarab to get em!
Knot 4 Me 12-10-2014 02:33 PM
I'm surpised they didn't clatter like a diesel!!
MER Performance 12-10-2014 02:42 PM
That there is the reason the rod bearings failed ! The hydrodynamic wedge of oil was lost, you just can't pull a piston, down on top of a counter weight.
MER Performance 12-10-2014 02:44 PM
That mess can be corrected, without, throwing it all in the trash.
Full Force 12-10-2014 03:02 PM
I am selling off old stuff and doing all new 540's local engine builder does matching my buddy and I will assemble and all issues will be gone... I can't wait!
wannabe 12-10-2014 03:31 PM
Thats why machining is so critical in engine building. People often forget that and focus on "the parts" .
Looks like "Goober with the green teeth" assembled yours. That would have to be very noticeable when hand turning that when first put together.
Wannabe
Full Force 12-10-2014 04:55 PM
6 Attachment(s)
Wannabe
here are some pics of the hackwork, I dont wanna clog this thread up with my mess, so here's the thread I have on it from when it happened...http://www.offshoreonly.com/forums/g...tml?highlight=
[ATTACH=CONFIG]534109[/ATTACH][ATTACH=CONFIG]534110[/ATTACH][ATTACH=CONFIG]534111[/ATTACH][ATTACH=CONFIG]534112[/ATTACH][ATTACH=CONFIG]534113[/ATTACH][ATTACH=CONFIG]534114[/ATTACH]
Unlimited jd 12-10-2014 04:59 PM
Wish the crank didn't need to be cut. I'd buy it. Buy I'm a picky ***** and only like std.
Full Force 12-10-2014 05:01 PM
Thats another reason I am starting 100% over with NEW stuff...
the deep 12-10-2014 05:24 PM
It would appear he ground the chit out of the counter balancer's trying to get clearance so it needs more than cut . Needs re-balanced imo .
Full Force 12-10-2014 05:27 PM
Crazy huh?
Cole2534 12-10-2014 06:30 PM
So what rods were those, FF?
Full Force 12-10-2014 07:01 PM
No clue, nothing on them but numbers that I have not yet found, supposed to be PBM/Scat
mike tkach 12-10-2014 08:51 PM
i don,t think the rods were the problem,lol.i think the problem was a bad builder with mis matched parts.
Full Force 12-10-2014 08:56 PM
Exactly. The rods did not fail the bearing did and spin because of chitty work
abones 12-10-2014 09:09 PM
It is a shame to see this type of work being done by a so called engine shop, but I believe this happens more than we know not only in the marine arena, but automotive as well. I can't see how these places continue to stay viable. Hard to believe!
Cole2534 12-10-2014 09:28 PM
They apparently have really high margins...of profit.
abones 12-10-2014 09:42 PM
Yes with just enough unsuspecting customers to perpetuate the madness
