Carb CFM?
Old 12-11-2014 | 03:16 PM
SB
Like above.
Way back when people thought they where cool if the had a "Holley 750 Double Pumper" on their street car.
Problem was, for 20yrs or so, the average 'performance' street car had a piece of schit factory 180-200HP 5.7L motor.
That was where the 'over carbureted' term mostly came from.
SB is online now
Old 12-11-2014 | 04:03 PM
Thumbs up
Originally Posted by Jonesyfxr
Summit racing has a carb calculator on their site. I've used it before and it's usually pretty much dead on.
http://www.summitracing.com/expertad...cfm-calculator
According to that calculator I need a 1031cfm carb. Thats good news , I was going to buy 4 and now I only need a single 1050cfm carb per motor.
That saves me a ton!
ICDEDPPL is offline
Old 12-11-2014 | 04:30 PM
http://users.erols.com/srweiss/calccarb.htm Carb size calculations you should be around 100 to 120% depends on some factors.
You all might like weiss's web site soime of the heads I have done are in there
http://users.erols.com/srweiss/index.html#jcalc
GO TO the home page for more info
turbo2256b is offline
Old 12-11-2014 | 05:38 PM
Wobble's Avatar
SORE MEMBER
change out the center body to an HP style such as the holley one and see an easy 20+hp gain.
http://www.ebay.com/itm/like/171069181378?lpid=82
Wobble is offline
Old 12-12-2014 | 06:17 AM
And if you send it to Dean Nickerson and he tootsie rolls the top of the carb for $900 it will make another 25hp on top of that!
Black Baja is offline
Old 12-12-2014 | 08:57 AM
Whats up with quick fuel? All week they`ve been closed for "the holiday" .
What fricking holiday??
Holley calls me back in under 15 minutes.
ICDEDPPL is offline
Old 12-12-2014 | 09:00 AM
SB
Probably at PRI . Lots of shops close for this.
http://www.performanceracing.com/tra...tion/index.php
SB is online now
