anybody with 496 HO using stainless marine exhaust? >
Old 01-05-2015 | 10:33 AM
288sunny's Avatar
Emerlad Coast PwrBt club
Default anybody with 496 HO using stainless marine exhaust?
just looking for thoughts, opinions? thinking of switching out dana marine for stainless?
288sunny is offline
Old 01-05-2015 | 10:57 AM
they work fine.
did you upgrade the engine in any way?
sutphen 30 is offline
Old 01-05-2015 | 11:53 AM
Got a friend that is using them and loves them for a couple years now. I am using his left over Merc 496 exhaust cause I cant bring myself to spend the money.
f_inscreenname is offline
Old 01-05-2015 | 07:54 PM
SM makes great exhaust. Yet, it's not an upgrade over the DM setup. The SM has short individual runners in the manifolds that dump into the open riser. Your current DM setup has longer individual runners that don't dump until in the riser thru a merge collector. The DM is a much better setup IMO. Nothing to be gained going to SM other than a lighter wallet. CMI sport tubes would be the only exhaust upgrade over what you have now, and Bobl at FTM has dyno results showing only a handful more hp over The DM.
I have a stock 496 HO and just can't justify the $ spent for returns on upgrading the exhaust. I've maximized the stock exhaust setup by removing the turbulators and welding 3" stainless extensions onto the risers to within 1" of the tips. This way the water does not mix in until inside the tip. While no major difference, it can't hurt.
Ryan00TJ is offline
