The new fel pro permadryplus gaskets >
Old 09-02-2002 | 08:21 PM
Default The new fel pro permadryplus gaskets
I think these are brand new. I tried some on my leaky valve covers and so far so good. They make them for oil pans too.
Has anyone had bad luck with these or are they too new to tell?
So far I like them. They are clean quick and easy. What do you guys think?
FlyFast is offline
Old 09-03-2002 | 03:28 PM
ForrestC's Avatar
Thumbs up
I've used 'em on three small-block oil pans, both steel and cast-aluminum, and I must say that they are very easy to install and don't leak a drop.
ForrestC is offline
Old 09-04-2002 | 03:34 PM
ForrestC's Avatar
Default Permidryplus Valve Cover Gaskets
Last night, rather than buying another $11.50 set of standard Fel-Pro cork valve-cover gaskets at AutoZone, I paid the $32 and picked-up and installed a set of of the Fel-Pro Permidryplus gaskets on my small-block premeter-attached cast-aluminum valve covers in my 18 Donzi. What a difference. No glue, no mess, no chance of a mis-fit or over torque, and they are reusable. Definately a cut above, and in time, they will be on every engine in every boat I have.
If you haven't check 'em out yet, the next time you need a set of valve-cover or oil-pan gaskets, take a good look a the the Permidryplus before you buy the same old cork or rubber gaskets. The oil-pan set is one piece and is a perfect fit.
ForrestC is offline
Old 09-05-2002 | 06:39 PM
Strip Poker 388's Avatar
Rob
try looking them up for a chevy truck part # may be cheaper than in there performance cat ,had some for about 4 years but there black, the blue is prob a updated material?
Strip Poker 388 is offline
Old 09-06-2002 | 08:10 AM
KAAMA's Avatar
Are these BRAND NEW from Felpro? The reason I ask is because Felpro came out with some valve cover and oil pan gaskets a few years ago that are a light blue color that I think were supposed to be resuable. I have heard these (especially the oil pan ones) really leaked badly!
KAAMA is offline
Old 09-06-2002 | 02:30 PM
Rob
Default f
the boat had the black ruber with steel core it never leaked on valve cover. the new blue one for the oil pans ssc and bbc are one peise with steel core, where the bolt holes are have steel oring you cant overtighten or squeeze out,these are supose to be the best out there.mike at felpro can give you part #,1800325-8886 hiper tech,jegs and summit should have
Old 09-06-2002 | 04:41 PM
Kamma,
I was told they are brand new in 2002. Do a search and some people are saying some nice things about them.
FlyFast is offline
Smitty
89
03-21-2014 10:27 PM
Strip Poker 388
Swap Shop
3
06-06-2009 02:19 PM
phughes69
6
08-16-2005 09:27 AM
boatinbill
3
03-08-2004 10:23 AM
olemissalum
1
02-01-2004 11:31 AM
