700hp 540s
MER Performance
4.500” x 4.250” 540 CID
9.6:1 CR
AFR 325 CNC Chamber_Hyd Roller
Correction factor_3.8% (1.038)
717.86 HP @ 5800
Mark commented the engine baseline dyno pull was ~685 and the additional 33 HP was found in the tune w/ the Holley EFI.
Bob
9.6:1 CR
717.86 HP @ 5800
Bob
No it does not need to be cnc'do what it means is you have a lot better chance of running higher compression with pump fuel with a combustion chambered designed today than 50 years ago. With the right chamber you can retard ignition timing therefore giving the motor less time to have a chance to detonate. The LS based motor / combustion chambers don't need much timing at all. If memory serves me when I had a conversation with a guy that specializes in LS motors (9 a week) he said because of the chamber design 21 degrees of timing is the sweet spot. 21 degrees of advance has alot less time to detonate than say 36 degrees (15 degrees to be exact). Hope this might shed some light on your question...
this off the ls forum.
Good safe place to start is 26 degrees at peak torque (4800 rpm) and ramping up to 28 degrees by 5600 rpm. You can then experiment with more timing or less. The 26/28 is very common for stock LS1 running 91-93 octane. Don't be surprised if your power doesn't change much with 2 degrees more or 2 degrees less timing. 26-28 degrees is the sweet spot for most stock motors.
