Bravo Drive
Old 09-03-2002 | 12:06 AM
26 CHECKMATE
Default Bravo Drive
I recently was putting a new prop on my boat and when I spun the new prop there was a point where it got a little more difficult to spin. Has anyone ever experienced this? My motor whent out so I didnt have a chance to try it after I found the problem, any ideas? As always any help is appreciated as always.
Old 09-03-2002 | 06:54 AM
further investigate...remove the prop....still exists??...remove the drive....still exists....do ya know how to rebuild a drive???
audacity is offline
Old 09-03-2002 | 07:09 AM
Offshore Addiction
ya, maybe just the wrong thrust washer,if not we know how to rebuild that drive......
Old 09-03-2002 | 12:00 PM
26 CHECKMATE
I removed the prop and it was still there, I didnt remove the drive though. I did also check the thrust washer it looked okay but it was brand new when I put the prop on. What do you think is wrong inside of it. It all still turns it just gives a little resistance at one spot.
Old 09-03-2002 | 12:10 PM
take the drive off and then see if it still does it????...if yes...u got issues....it is in neutral right???
audacity is offline
Old 09-03-2002 | 12:31 PM
26 CHECKMATE
It is in neutral, what do you think it could be?
Old 09-03-2002 | 12:59 PM
a bilion things!...take it in if you don't know...it could save you that drive and a TON of $$$ later!
audacity is offline
Old 09-03-2002 | 10:35 PM
26 CHECKMATE
I will have to see if I can find someone to take it to
Old 09-03-2002 | 10:52 PM
Drain the gear lube in the drive and check for metal fragments. I'm betting you'll find some.
Griff is offline
Old 09-04-2002 | 06:11 AM
how old is the drive??? OL or OM serial #???
audacity is offline
