Diacom software ?? - where to hook up on 525EFI ? >
Old 01-15-2015 | 09:26 AM
Default Diacom software ?? - where to hook up on 525EFI ?
I bought the software and the appropriate adaptors, but I cannot figure out which connection to plug it in to... can anyone point me in the right direction? pictures would be FANTASTIC!!
HyFive578 is offline
Old 01-15-2015 | 09:30 AM
should be a capped connector by the back of the engine.will be grouped w/ the 3 connector trim switch plug.they have labels on most on the connectors.
sutphen 30 is offline
Old 01-15-2015 | 09:52 AM
On the 525, the plug is on the port side of the intake and is attached to the SS bracket that holds the throttle cable. It will be on the back side of the SS plate. You will have to unplug it from the cap that it's plugged into.
Eddie
Young Performance is offline
Old 01-15-2015 | 10:05 AM
if he posts a pic of the engine,,could put an arrow on it and show him.
Old 01-15-2015 | 10:39 AM
It's on the back side of this plate.
Attached Thumbnails Diacom software ?? - where to hook up on 525EFI ?-dsc03412-large-.jpg
Old 01-15-2015 | 10:48 AM
thanks for the pic,at my advanced age,I forget were these plugs are.but they are usually easy to spot.
Old 01-15-2015 | 11:35 AM
eddie's Avatar
Is that a stage 1 - 3 kit on the 525 ? If so which one and how did you like it?
eddie is offline
Old 01-15-2015 | 11:40 AM
Dave M's Avatar
Veteran: Navy
What version is your Diacom SW? I bought it a back in '2005 when I had a 496HO. It worked great. It still works with my 525efi but I noticed it seems to put some dummy data is some of the fields.
Dave M is offline
Old 01-15-2015 | 11:48 AM
Perfect!!! THANKS EDDIE!!!!
Old 01-15-2015 | 12:00 PM
Not sure.. I'm sure it's the latest version.. I just bought it about a month ago.
