What head should I use
Pushrods push tubes same thing different names. I am building off of a 330 hp 454 block some parts are new some are used. So do you think that the 088 will be my best option? Lol if I used my head I would have bought a 14 foot aluminium boat with a 15hp Jonson on the back and just went fishing
Well it's a good option if you want a nice head that is bolt on ready and don't want to spend a ton of money. Machine work is expensive, as are all the good parts needed to make it work. If your using a flat tappet cam you will want different springs, so I'll sell you my heads without springs for $650.00. That 525 cam isn't going to need roller springs. Is the 188 head the best head out there, no. But its a good head that was brand new prior to me using it. So it has only 24 hours of run time.
As for using used flat tappet cams, i personally wouldn't do it. Flat tappets need to spin, your cam already has a wear pattern in it and the lifters "may" not spin. At which time, your going to wipe out the cam, lifter and your engine. A used flat tappet lifter is a 100% NO!
There are ways to skimp and save money but reusing old lifter is not one of them. Just my opinion.
188 heads are mkiv, 088 are gen 5/6.
Wear patterns on flat tappet cams will cause 10 pages of debate. With low zinc oils, and good valve springs you are way better off with a roller cam. Or at the very least a new flat tappet. I don't believe the merc 525sc cam is the same as the 420. The hawk 525 might be though.
Here is a link to the cam I have I think. When I bought it the guy said it is from a gen 5. I thought gen 5 were rollers am I wrong
http://www.cranecams.com/product/car...detail&p=24005
Sorry but my cam is for a gen 5 but has the same specs as the one in the link
Never mind got to quit going on oso while on holidays
Oops- it's been a while you are right the 088 is Gen V. Either way I would not reuse a flat tappet cam that came from another motor and there is zero chance that I would ever use someone elses old flat lifters.
That cam you have posted is a flat tappet. Read the description of the cam, it clearly says flat tappet. I hope you didn't pay much for it. Everything is a learning experience. If I was you I would scrap that cam and buy mike's cam. That along with my heads would make a nice combo that wouldn't break the bank.
