What head should I use >
Old 01-17-2015 | 10:08 AM
  #41
i think the efi cam is the same as the carbed cam except for a wider lsa.
mike tkach is offline
Old 01-17-2015 | 10:18 AM
  #42
nope,,efi cam is 230,236 carbed cam is I think 222,228
sutphen 30 is offline
Old 01-17-2015 | 10:20 AM
  #43
just shows you how effiecent a carb is at making the numbers,,less cam.
Old 01-17-2015 | 10:28 AM
  #44
HP500 Carb Camshaft. 222/230, .576/.598 110LSA
500EFI camshaft 230/236 .598/.610 114LSA
I wonder what was behind Merc's choice on the HP500 cam. They were known for reversion with the 110LSA. One of the only cams I've seen in a mercruiser/mercury racing engine with a 110LSA.
MILD THUNDER is offline
Old 01-17-2015 | 10:39 AM
  #45
i knew you would post up the info faster than my old azz could find it,lol.
Old 01-17-2015 | 10:40 AM
  #46
Hmm lots to think about I found a set of 088 heads with 30 hours on them for 450. I am thinking about going with the 500efi cam. I know I will need to change out springs to match the roller cam. But will I see any real gains with the 500efi vs the 420 cam
demax990 is offline
Old 01-17-2015 | 10:42 AM
  #47
i would say that the tighter lsa had something to do with it.
Old 01-17-2015 | 10:59 AM
  #48
not sure how much power gain but flat tappit cam is old school.the hyd roller setup is the way to go.
Old 01-17-2015 | 11:05 AM
  #49
no way,icl of 106 and 8 degrees less.carb cam kinda sucked from the get go,,but swap it out for a 731 and the motors really responded and didn't revert at 850rpm.
Old 01-17-2015 | 11:25 AM
  #50
Ok so who wants to sell me a 500efi cam with lifters and rockers for a very very good price as I am just a poor guy doing a low cost build
demax990 is offline
