The GM/Merc Rectangle port head. Discuss.
#33
Dude, what in gods name is that cam doing in a 555 cubic inch engine? lol.
Anyhow, the program with your combo is coming back around 490HP. Going from an 800 Carb to a dominator, only picked up about 7hp, which im not surprised. Your just not making enough power to take advantage of a bigger carb.
Going with the crane 651 specs, bumps it up slightly over 1HP per ci, to 570HP with a 1050.
Switching to a set of AFR 305's with CNC chamber, still with the 651 crane cam, made the numbers jump to 671HP with a 1050.
#34
As I went back to look at what you have there, I happen to notice you said "HP500" cam??? OMG.
Thanks for spec'ing it out for me. Any other suggestions from the group are welcome on which direction I should go.
#35
#36
Bought the boat set up this way with M3s on it. Went back NA with what I had to enjoy it for the rest of the season. Now in the process of cam, carb, intake hunting. Don't really want to lay out the $$$ this year on new heads.
#37
#40
I don't mind at all. Its a bit old school but it works. 509 cu , 10.3 comp, 630ish on the cam (roller of course) single plane, 850 race prep carb , msd, gm crank, good rods 32 degrees timing. There is a bit more little stuff but that kinda covers it. No porting, just built tough. They run like a clock. Knock on wood.
