oil restrictors and pushrod restrictors? >
Old 01-28-2015 | 06:49 PM
SB
Click on here: http://www.racingsprings.com/Multime...b/kb513102.pdf
And look at the section of heat vs valvespring psi changes as installed.
Oil cools your valvetrain.
Use plenty of oil and make sure your oil cooler keeps it to the correct temp.
SB is offline
Old 01-29-2015 | 08:25 AM
need the cooling to valve springs...in drag race engine not run long enough to be a issue...
ezstriper is offline
Old 01-29-2015 | 09:19 AM
bcfountain's Avatar
Registered User
oil cools and carrys the heat back to the cooler to release the heat into the water and out the system.
bcfountain is offline
Old 01-29-2015 | 10:06 AM
Actually they are using spring oilers on drag stuff. What they have found is it makes an $800 set of valve springs last a lot longer. We are talking 1.250" inch lift stuff.
Black Baja is offline
Old 08-06-2016 | 03:38 PM
Craney's Avatar
A friend called me and asked about oil restrictors,he was told he needs them, it is a solid roller motor. The instructions say on the lifters not use restrictors.
Craney is online now
Old 08-07-2016 | 06:20 AM
Restricting oil to the lifters is not a good idea. Today's lifters are designed with high pressure pin oiling. Restricting oil to the lifter defeats the design purpose that went into the lifter and is asking for trouble.
Old 08-07-2016 | 05:45 PM
so I think this all comes down to, is your friend going to listen to some guy who told him to use restrictors or the people who designed and built the lifters he is using.
compedgemarine is offline
Old 08-08-2016 | 06:06 AM
bad idea on a boat
Old 08-08-2016 | 06:13 AM
Craney's Avatar
His isn't going to use the restrictors.
