Merlin Intake on a 454 >
Old 01-31-2015 | 05:38 PM
Default Merlin Intake on a 454
Thoughts on using a Merlin intake on a .030 over 454 with AFR 305cc heads w/9.5 comp. What carb would be appropriate.
sbslinde is offline
Old 01-31-2015 | 06:12 PM
You have the wrong heads on that engine. You may not even have enough torque to get on plane.
You may want to go this route
MILD THUNDER is offline
Old 01-31-2015 | 06:57 PM
The bitterness of mismatched parts remains long after the sweetness of a low price is forgotten.
ICDEDPPL is offline
Old 02-01-2015 | 11:08 AM
you need to also post your cam. The Merlin intakes have huge runners. If you are going to run a single plane go for a Dart or Vic Jr. If you are not going to spin it high, I have a nice Edlebrock Performer RPM I'll make you a good deal on.
endeavour32 is offline
Old 02-01-2015 | 11:33 AM
SB
800-850cfm Holley.
SB is offline
Old 02-01-2015 | 12:44 PM
and what is the 454 bottom end? rebuilt 330? you will never spin it high enough to get that top end breathing the way it should. afr 265's are the hot setup for stock 454's.
dereknkathy is offline
Old 02-02-2015 | 09:28 AM
Mag 454 crank 4 bolt mains. Thanks for the advice on the Merlin. Cam will be 230/235 dur .600/.620 lift 114 ls
sbslinde is offline
Old 02-02-2015 | 10:25 AM
put a victor jr and an 850 carb and you should be over 500hp.had about the same set up w/ 9.3-1 comp,vic jr and a bolands 930cfm carb,527hp,517tq(2 peaks),that motor ripped in my 30' sutphen.
sutphen 30 is offline
Old 02-03-2015 | 01:28 PM
Victor Jr sourced from Orlandi performance. Thanks Brian.
Now to find an 800/850 carb.
sbslinde is offline
