Fuel Pump
Old 02-24-2015 | 01:11 PM
  #51
ARP says do not use on any Roller cam so not sure why Clay would recommend it, either way I`ll just go back to pumping gas.
ICDEDPPL is offline
Old 02-24-2015 | 02:40 PM
  #52
I guess Clay Smith is in the business of selling fuel pumps, not cam shafts, so he is only going to know what works on his end of the push rod.
I'm with you on that - wondering if I should just stay with an electric pump. I would be the guy who has a pushrod that mushrooms out.
Budman II is offline
Old 02-24-2015 | 02:48 PM
  #53
No doubt Budman, if it is going to hapen it would for sure be to you!! BUT this year will be different for you I see good luck coming your way!
abones is offline
Old 02-24-2015 | 04:27 PM
  #54
From what I see, after looking thru catalogs here from Howards, Comp, Crane, Crower, moroso, and arp, its seems you have 3 styles of pushrods.
One with a bronze tip, to be used with steel camshafts.
One with a steel tip, to be used with cast iron camshafts.
A new lightweight blended carbon polymer, advertised to be used with either a cast iron, or steel camshaft.
Unless theres something else out there, thats all I see available from those sources. Has anyone used one of the lightweight carbon polymer rods ?
MILD THUNDER is offline
Old 02-24-2015 | 04:32 PM
  #55
I am "tempted" too......but??????
TAStevens is offline
Old 02-24-2015 | 04:37 PM
  #56
Yes
Black Baja is offline
Old 02-24-2015 | 04:47 PM
  #57
SB
I'm suprised no one has brought up type of oil yet.
Roller Tappet people, for the most part, feel safe not having to deal with 'special oil' for flat tappets and etc, but can we consider the fuel pump pushrod in the same league ? Obviously, less spring pressure, however........
This has been a good round table discussion, therefore I thought I would throw something else out there in case....
SB is offline
Old 02-24-2015 | 06:13 PM
  #58
Good Point! OIL! Brad Penn! Ya...Im a Dealer.....but also have some GREAT results I could share.
Old 02-24-2015 | 06:19 PM
  #59
I thought about that. But have been taking enough of a beating around here lately. Im no longer at the round table, they stuck me at a square table in the corner.
Old 02-26-2015 | 10:07 PM
  #60
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Here boys I found something for you . Roller cam approved ! http://www.scorpioncheckout.com/category_s/235.htm
the deep is offline
