BBC Rocker Arms >
BBC Rocker Arms
BBC Rocker Arms
Old 02-23-2015 | 07:10 PM
Default BBC Rocker Arms
Although I have Jesel Shafts on by Blown motor......Whats the hot ticket for stud mount rockers? .630 lift Hyd Roller 572cid Leaning towards Comp Cams
TAStevens is offline
Old 02-23-2015 | 07:43 PM
vintage chromoly's Avatar
vintage chromoly is offline
Old 02-23-2015 | 07:52 PM
Scorpion pretty good for the money
Unlimited jd is offline
Old 02-23-2015 | 08:10 PM
Agree, I'm running a set and happy so far.
Quick2500 is offline
Old 02-24-2015 | 09:04 AM
i have jessel to not happy with them! i am looking at crower set up and so far they are looking good.stainless steel the way i am going .
bajabob is offline
Old 02-24-2015 | 10:41 AM
Could you please explain what is wrong with the Jesel stuff?
Black Baja is offline
Old 02-24-2015 | 12:43 PM
GPM
Just curious, with the rocker arm being one of the most abused parts in an engine, why not go for the strongest one available. I'm sure some will say it's overkill, until they have a bunch of broken pieces banging around inside their engine.
GPM is offline
Old 02-24-2015 | 12:59 PM
EVERYTHING about these new engines I'm building is about RELIABILITY with Power. Not putting anything in it that saves $20! Leaning towards Comp Cams Ultra Pro Magnums. Personally havnt had any problems with Jesel Shafts, you WILL have to slightly "modify" them to get the geometry dead on though! VERY IMPORTANT! I think if people have "problems" they most likely just took them out of the box and threw them on?!
Old 02-24-2015 | 03:30 PM
You are right. Improper setup (geometry, pushrod, spring ect.) part fails and the manufacturer get blamed for faulty parts.
For your setup I would highly recommend the Scorpions. The Comp stuff leaves a lot on the table to still be desired. The engineering of there steel arm puts more weight on the valve and that's a big no no. With that sort of lift and a hydraulic lifter an aluminum arm will give you many trouble free hours. I've ran the Scorpions @.721 lift 50 hours 6,000 or above.
Old 02-24-2015 | 04:04 PM
Full Force's Avatar
I am using Scorpion Endurance on my new engines, no reason to have the heavier steel on my application, the life is gonna be just as long, if rockers are set up right there is no failures to happen from the actual rocker being aluminum over steel...
Full Force is offline
