What's wrong with AFR's exhaust port? >
Old 03-02-2015 | 09:09 AM
  #91
KAAMA's Avatar
Originally Posted by sutphen 30
most of the gains lately have been wet flow around the seat area.Darren Morgan worked over a set of nitrous heads for us,,he got us 3cfm,but in top sportsman and 600-800hp of nitrous,you need every bit of flow.
What did Darrin Morgan charge for something like that, Bill? I am wondering how many CFM numbers it takes to gain or make 1-hp??? Does anyone know?
Like I have said previously, if it is for a car race application where saving a pound of weight here and there as well as low as 1-hp, then maybe I can understand these small increases for the time and expense involve for a drag car clocking time in the 1/4 mile....or a circle track car, but I think a boat is a whole different animal and these CNC ports have already filled the gap considerably.
I will admit that I like the ports to be as efficient as possible, and I am sure every little bit helps, and I suppose it depends on how much $$$ a person wants to spend, but where do I draw the line for a pair of hi-zoot offshore engines with supercharging that are already equipped with CNC ported heads that are going in a pleasure boat? Are we splitting hairs here?
KAAMA is offline
Old 03-02-2015 | 09:41 AM
  #92
You can have two heads that flow identical CFM and have the same port volume. One head makes 50 more horsepower than the other. CFM really means nothing anymore and not the way heads are built/ designed. The reason CFM numbers are posted by manufacturers is because the numbers sell heads. Buy a $10,000 set of billet heads and see if you get flow sheets with them. In the words of Darin Morgan the three things that really matter with a port are: air speed, air speed, air speed.
Black Baja is offline
Old 03-02-2015 | 10:06 AM
  #93
Irrelevant to this discussion kinda, but good read you guys might like
http://www.enginelabs.com/engine-tec...r-your-engine/
MILD THUNDER is offline
Old 03-02-2015 | 04:03 PM
  #94
articfriends's Avatar
Anything can be improved upon IF someone takes the time and is really skilled, there could be a step backwards too though if someone hacks on something. My 540 made 945 hp blown with 315 afrs, on next refresh did more porting to 502 mag intake, Bob Madera spec'd a bigger cam and Rick Lapouttre who is our very talented local head porter did his mods to my afrs and motor made 1115 hp, what gave it the biggest gain, couldnt tell you. The heads were converted to 2.300 valves when it made 1115 I do know that, Smitty
articfriends is offline
Old 03-02-2015 | 04:40 PM
  #95
Originally Posted by ICDEDPPL
I`m sorry but there`s no way a CNC machine replaces guys like Jim V or my guy Mike @ High Flow Heads.
Plus those guys paved the way for those those CNC programs thru tons of trial and error.
I`ve heard of the great work Jim V does and locally to me what Mike did with the combustion chambers is an art. These guy s are like sculpters .
That being said those fully ported CNC heads are pretty damn good out of the box compared what was available years ago.
Replace entirely? No, probably not. Do it faster, more accurately, and with exact repetition? Yes.
Cole2534 is offline
Old 03-02-2015 | 05:51 PM
  #96
Both a blessing and a bane, the skilled craftsman teaches a programmer instead of the next generation
buck35 is offline
Old 03-02-2015 | 06:02 PM
  #97
SB
You guys ever wanna know who designed the port (and what the application is for) on a certain CNC'd head ?
It's not like every Casting Company / Cylinder Head Manufacturer has a well known 'go to' cylinder head porter in their arsenault.
Just a question. That's all.
SB is offline
Old 03-02-2015 | 06:07 PM
  #98
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Tell me what you know about the AFR 315's uncle SB . I paid for the very very best ( for my application ) and that's just what I expect to receive . Are we really discussing a tweak that will net 1hp @ 7000rpm . Most of us will only be turning 6000rpm if that . From what I've seen and heard by the brothers that have used these heads in marine applications I believe I'll be well pleased . http://www.airflowresearch.com/performance.php
PS: This post was in no way intended to disrespect Jim V. I believe he has earned the respect of the OSO brotherhood and that is not given freely .
the deep is offline
Old 03-02-2015 | 06:12 PM
  #99
SB
Over achievers for the most part. Unless you want to spend more.
My post was about all cnc heads in general. Something to take in account when buying anyone's CNC head...that's all.
SB is offline
Old 03-02-2015 | 07:09 PM
  #100
at some point asingle man ported a set of heads,,they worked,,they got cnc'd splashed..
sutphen 30 is offline
