HP increase
Old 03-08-2015 | 02:31 PM
Why not step up to a 4.375 stroke?
Black Baja is offline
Old 03-08-2015 | 06:09 PM
Tinkerer's Avatar
Been told by many that it is not a good rod ratio. These are stock standard deck blocks.
Tinkerer is offline
Old 03-08-2015 | 06:18 PM
Sounds like the many you talked to arent very good at math and dont know what they are talking about.
Old 03-08-2015 | 06:27 PM
SB
I have a harder time with people running 4.5" strokes in standard height (aftermarket) blocks, but a handful do.
Many people running 555's too, even in 502 blocks. IMHO wouldn't worry about it...especially marine rpms.
SB is online now
Old 03-08-2015 | 06:46 PM
Tinkerer's Avatar
SB - I plan on turning this engine at least 6500 RPM.
Tinkerer is offline
Old 03-08-2015 | 07:06 PM
Rookie's Avatar
Please enlighten others. I've talked about doing 4.375's for a while, but everyone I talk to says it's a death sentence in a longevity marine engine. Drag racing all day, but not marine.
If Tinkerer wants I will move to it's own thread.
Rookie is offline
Old 03-08-2015 | 07:39 PM
Just out of curiosity what did Jim and bob think? U did ask them right? I know Jim has done a ton of 540 heads and builds. You gonna dyno it?
getrdunn is offline
Old 03-08-2015 | 07:58 PM
4.375/4.250=1.5% (increase in crank angle)
6.385/4.250=1.5 (Rod ratio 4.25 crank)
6.385/4.375=1.45 (Rod ratio 4.375)
These numbers are so close it's not gonna affect anything (except the peanut gallery). Where it gets better is you are moving the pin up in the piston .0625 which makes a lighter piston. The less weight you have at the end of the rod the better off you are. The 4.375 is a better motor.
Old 03-08-2015 | 08:09 PM
Rookie's Avatar
These numbers are so close it's not gonna affect anything (except the peanut gallery). Where it gets better is you are moving the pin up in the piston .075 which makes a lighter piston. The less weight you have at the end of the rod the better off you are. The 4.375 is a better motor.
I agree and some will build it, but I don't know anyone that will stand behind it.
Also, it might only be an increase in 1.5% as you stated. But, 1.3% might be over the critical angle. (The limit) I have no clue, just stating for discussion not argument
Rookie is offline
Old 03-08-2015 | 08:30 PM
Tinkerer's Avatar
I haven't talked to anyone outside of these websites.
I have just been kicking a few thoughts around. I plan on building the 598 but don't really want it yet. I have a lot of other things that I need to do to the Daytona that are going to be pricey. The 598 is going to be over $20,000 in parts alone.
If I can rebuild the spare 502 and go from 650 to 800 HP I would be real happy with that and the other changes to the boat. and it would cost only about $5,000 to do it. I was thinking that if I can just replace the crank, rods, cam, lifters and the other wear parts. I was hoping to reuse the pistons I have now.
I could probably get this all done and put it together before spring. I have good heads ( they may need to have some of the wedges ground out ) and a good intake and carb. I need to upgrade the ignition system. I plan on getting a crank sensor. ( last summer when I was checking my total timing - above 3000 RPM it was all over the place.
Tinkerer is offline
