Oil filter... >
Oil filter...
Oil filter...
Old 03-14-2015 | 08:10 PM
  #91
Originally Posted by SB
As much as I joke about "Where is he"
I hope to God no !!!! He would send PM attacks too,,,,,and then hrs later PM to aplogize.
A true Psycho.
None of us need nor deserve that.
ctraub deserves that.
sutphen 30 is offline
Old 03-14-2015 | 08:18 PM
  #92
SB
Originally Posted by sutphen 30
ctraub has never installed an oil filter
Fixed and on subject !
SB is online now
Old 03-14-2015 | 08:41 PM
  #93
So all of the past oil filter threads heavily endorsing Wix (which I use) are . . . . . . . . . wrong?
thirdchildhood is offline
Old 03-14-2015 | 09:09 PM
  #94
Originally Posted by chrisf695
Just remember bigger isn't always better . In all seriousness though, it's true. If the application doesn't warrant the bigger filter, it isn't improving anything. Yes that filter does not have a built in bypass valve.
***For anyone with the GM oil bypass valves build into your block, an oil filter without a built in bypass is the proper one to purchase. IF your block is plugged, select a filter WITH a bypass valve built in.
i b?ught a remote mount because my manifold mount only allowed a short filter. the mount uses 2 filters stock 502 mag. is this ok?
stimleck is offline
Old 03-14-2015 | 09:11 PM
  #95
well my engines are still running and its been using 088's,,cross overs,efi and wix filters w/ mobil 1 syn oil(15-50)..those puppies should be dead by all accounts here.sorry,couldn't resist.
Old 03-14-2015 | 09:23 PM
  #96
Originally Posted by bup
this surely would be even a better thread if the borgie man was around. Where in the world is he. Can we vote to let him back in ?.
no!
mike tkach is offline
Old 03-14-2015 | 09:37 PM
  #97
when i am spinning 6300-6400 rpm and making 1200+hp i don,t care about micron,s i care about OIL FLOW.and the wix racing filter does what i need it to do.i change my oil&filter at 10 hrs or less so it,s a common sense thing for me.when i tear engines down that have run nothing but wix racing filters and all lubricated parts look as they did when installed new im sold.in my car&truck engines that go 5000 miles between oil changes the wix racing filter is not what i use but it is still way better than what super lube install,s when they change your oil.carry on fella,s,jmo but works for me.
Old 03-15-2015 | 04:05 PM
  #98
Moving on a bit....
I'm still running the OEM lines/relocation unit from the 454 Mag that came with it, but understand that system is pretty inadequate. So what's the hot set up? At the very least change the lines? Is there a kit to buy?
Baja Rooster is offline
Old 03-15-2015 | 04:38 PM
  #99
Good pic of more properly cut open filters:
1st, a typical filter cutter, although many other styles....pretty much all styles use rolling cutting wheels like a can opener:
I got in on this a little late however this is a great display of filters. Amazing the difference of the brands -inners/filters
getrdunn is offline
Old 03-15-2015 | 04:58 PM
  #100
Originally Posted by Baja Rooster
Moving on a bit....
When I ran the stock mag set up years ago I found it to be fine and had the ability to use different length filters. Currently I'm using canton block adapters with head mount housings. The size line you use is your preference. I know individuals who use 8 AN on up to 16 AN. I use 12 and feel very comfortable it's plenty big. If you use all AN fittings and braided lines be prepared to spend some bucks. Will be nice when complete though.
getrdunn is offline
