Here's a head scratcher! Piston rings...
My wonder is why GM would use the same part number but change the design.
Unknown. We were both pretty sure of the fact that with the part numbers the same that this wouldn't have been an issue. So far, I'm stumped as to the difference.
Joe, everything should be MKIV. The stamped part numbers on the pistons are GM 3999295. They are "supposed" to use a 5/64 5/64 3/16 standard ring pack. Looks like I could order Hastings 2M4718 and get the right set to bastardize things, but that just seems rather jerry rigged to me.
The better book , once i again have possesion of it has all and i mean all spec measurements ect of about every v8 piston in the known galaxy. Hence my earlier reference of hugging . Because there is indeed some strange stuff going on out there
Well, I got into a whole bunch of ring catalogs. And they reference both shallow and standard rings across the line of 454 engines. It's a crap shoot.
The pistons I have were only available in later engines. Somewhere GM made a change. Oh well, my issue to deal with.
The expanders are the issue. I measured the oil rings. They're exactly the same.
Perhaps I can reuse the expanders and go from there. I'll do a drop test in the morning to see if they work.
