496 NA or SC? >
496 NA or SC?
496 NA or SC?
Old 03-29-2015 | 03:10 PM
Default 496 NA or SC?
Anyone use a 525 sc (177)blower on a 496? If so just curious what kind of numbers you were pulling? Currently Im close to 600 hp after getting valvetrain stabilized however the compression is just under 10:1.
I was debating on having valako open up the chambers (dart pro 1's) and using thicker head gaskets to try and achieve low to mid 8:1. These engines will only see short spurts at full throttle.
Let me know if you have any experience with!
Thanks,
John
getrdunn is offline
Old 03-29-2015 | 05:13 PM
I wouldn't get carried away trying to open up the chambers on a pro1 head. The deck of the head is already thin to begin with. The pro1's were designed to be a lightweight aluminum head. The race series is a much better head for this kind of work. Sounds to me like you are thinking about spending a ton of money for not much gain. It is an immense amount of work to properly open up all the chambers in a head.
Black Baja is offline
Old 03-29-2015 | 05:57 PM
Ok... Let's just change the original thread then. Has anyone had any experience with 525 sc blowers on a 496? If so what kind of numbers/results did you have.
Tks
John
getrdunn is offline
Old 03-29-2015 | 06:26 PM
Rookie's Avatar
Damn it! Once again I have to scrap my heads... When will I ever catch a break.
Rookie is offline
Old 03-29-2015 | 06:27 PM
454 is about as big of an engine a 177 is good for.it is just to small for almost 500 inches.
mike tkach is offline
Old 03-29-2015 | 06:41 PM
No doubt.... Lol
getrdunn is offline
Old 03-29-2015 | 06:54 PM
Rookie's Avatar
Originally Posted by getrdunn
No doubt.... Lol
My PRO1's are about 128/9cc's. Jim does a lot of chamber ports give him a call, it can't hurt. And like others said the 177's I believe are a little small from my readings.
Oh, and Jim has 2 496 short blocks ready for assembly.
Did you receive the alternators all right?
Rookie is offline
Old 03-29-2015 | 07:27 PM
Talked to him this morning. Ya he said could easily get 128 on the chambers. I kinda figured it wouldn't be advantageous with the 177's. will probably off them and look for a couple 250's. I pretty much figured the 177's would run out of breath as well as build to much unwanted heat. No biggy! Mean while they make great paper weights and a place to hang my jackets.
Mounted the Alts this morning. One of them sound a little gravely when I spun it but then realized one of the case bolts was backed out about 1/4". Tightened and seemed to clear it up. They look great. Sure they'll work fine. Tks for the quick shipping.
John
Will see v this week. A friend grenaded his blown mustang and sending him to Jims.
getrdunn is offline
