-   -   silencers (https://www.offshoreonly.com/forums/general-q/324956-silencers.html)
35fountain 04-09-2015 02:16 PM
silencers
3 Attachment(s)
Hi, I just removed all diverters and switched over to thru hull only. I will miss the silent choice so I was thinking about a switchable silencer.
[ATTACH=CONFIG]539679[/ATTACH].[ATTACH=CONFIG]539677[/ATTACH][ATTACH=CONFIG]539678[/ATTACH]
The larger silencer is Gil and the smaller is cmi..Both are 4" clamp on
Does anyone know which silencer will fit my boat. I am concerned about the center 2 pipes. Seems like I only have 3 " between them
Furuvagen 04-15-2015 04:32 PM
I have a '93 Scarab 38 thunder with twin 496 Engines (stock HO, 425 hp). It has the Gil mufflers on it, and yes - they are 3" inside, but it seems like it works. I actually think that these might have been a factory option (since everything else on the boat is bone stock), but I'm not sure. However, the switchable feature has gone south, so I'll have to see what I can do to fix it. They dampen the sound quite a bit even in the "open mode" though: I can have a normal conversation in the cockpit at idle speeds, which is nice in a way...
...but I miss the crisp rumble! I might rebuild these into a switchable external silent choice system instead...
I don't think that any of the suggested mufflers will affect performance, unless you have more than 500 hp per Engine.
apollard 04-16-2015 07:25 AM
Check into the GGB inserts. I put them on my boat and dropped the sound level quite a bit, but still have that BBC rumble. No affect on boat performance.
