-   -   502 Mpi procharger to 540 (https://www.offshoreonly.com/forums/general-q/325013-502-mpi-procharger-540-a.html)
louisfever 04-11-2015 06:44 AM
im interestd in buying a 1998 scarab 29 that has a 502 mpi with a M-1 procharger on it !! Here in malta the curent and humidity are a setback for speed thats why it only goes 65 mpi with 3.5 of boost with 87 octane fuel !!! 87 octane is all we have here in malta.. Is it possible to stroke it to 540 for more power ????????
And what othere modifications will i have to do with the Ecu etc ?????
The Ecu ir remaped already cause of the procharger .....
I also thought of raising the X dimension 2 inches cause its very very low .....
What to you guys have to say about this ...... Really need your help !!! Thanks
ezstriper 04-11-2015 07:03 AM
I'm not sure the M1 would support the 540 ??? the whole fuel and oil systems need to be redone as well as some work on the fuel rails with merc EFI. eddie young can fill you in on these, aftermarket EFI would be a far better choice and could be tuned better in my opinion..sure other may thing otherwise...to raise the X is going to require a LOT of work...shorter drive might be a better choice, or a better hull.
Unlimited jd 04-11-2015 07:18 AM
I'd think that boat should do 65 stock ?
sutphen 30 04-11-2015 08:17 AM
procharger is too small,your injectors will need to be changed and a remap of the fuel/spark maps.fuel rail needs to be modded on 1 port,think port 7 but a quick look will show you the small hole,,unless you have a newer style fuel rail.
louisfever 04-11-2015 10:24 AM
Here in malta when a boat comes from the us, if the prop is a bravo 26 in the usa , when it comes to malta you have to put a 24 on cause of our conditions .... The problem here is that there isint a well skild person to turn to help if you want more power unfortuneatly thats why im baffeld on what to do
sutphen 30 04-11-2015 10:45 AM
fly me over for the summer.I'll do it.:D
louisfever 04-11-2015 11:22 AM
If i raise the x dimension by 2 inches, will it improve my top speed cause the drive is really low in stock form ????? How much rpm's will I gain ??????
SB 04-11-2015 11:24 AM
x 2 !
I looked Malta up earlier too...Seems like a great place !
Edit in: maybe not summer for me. But there seems to be a 8 month window in the year this northern white boy would truly enjoy.
louisfever 04-11-2015 02:48 PM
Here in malta we have great weather and the summers are great and lots of gorgous bays to go boating to :)
sutphen 30 04-12-2015 08:24 AM
I belive my friend left his stock,,we just kept upping the power of the 502,we got him to 80mph but was really loose.built a 540 w/ the same cam and comp,did an easy 82mph w/ a loose 84-85mph.then he sold the boat.
I be dropping off his world product heads I did for him(I hate those head,did I say that before :D) I'll tell him to chime in w/ more details.
louisfever 04-13-2015 06:43 AM
Thanks for your responce guys ... I think the best thing is leave it the way it is cause its pretty reliable and prop it well and if i want to go faster, gett a bigger motor :cool-smiley-011:
SB 04-13-2015 09:13 AM
See Post #10 here: http://www.offshoreonly.com/forums/g...-question.html
Some of are thinking you have other issues than not enough power, if the motors are good..
louisfever 04-13-2015 02:08 PM
SB i understand u think it not fast enough for the power it has but ill give you another example ...
My buddy just bought a 1996 Fountain Fever 27 without power and Called Joe Corretti of Coretti racing engines and ordered a custom built 540 ci dart motor making 600 Hp for the boat ...
It runs 70 MPH @ 5200 Rpm with a bravo 24 prop !!!!!!!!
Ive seen that there in the USA that a fountain fever 27 runs 70 Mph with a HP 500 blue motor !!!!!!!!
See the difference !!??!!??
Here is very salty also !!!!!!!
airjunky 04-13-2015 09:39 PM
The m1 will add power to a 540 and a good 540 will not be stessed by it ever. Just dont expect a lot of boost and dont try to spool it to 80,000rpm to get your boost back.
besides a proper 540 with 10 or so psi is going to take you directly into drive obliterator status if your still stock
you can always sell a functioning m1 to offset the cost of 540 upgrade too.
airjunky 04-13-2015 09:41 PM
That thing must have a 4.25 upper pulley on it or loose inlet tube hose clamps.
how much does it cost to import cases of 104+ octane boost there
louisfever 04-14-2015 05:51 AM
We have that available here but it gets expensive cause we use our boats alot here
