Blue 500s hourly maintenance ??? >
Old 04-13-2015 | 03:13 PM
I believe that 500efi's can do full hour run down as well but only on the motors that are 01 and newer if I remember correctly. But I could be wrong it has happened befor lol
1989mach1 is offline
Old 04-13-2015 | 03:18 PM
Before u buy have a full survey done and also a compression test and a leak down test done on both motors that will tell you alot about the boat.
Old 04-13-2015 | 03:22 PM
I was going to look at them first and if they still had my interest. Than have a survey done.
fordf350 is offline
Old 04-13-2015 | 03:39 PM
For shure thats the way to go. Its well worth the money to have everything checked out be for u thow down the coin.
Old 04-13-2015 | 03:41 PM
What years r the boats?
Old 04-13-2015 | 03:47 PM
Originally Posted by kennyo
I've heard and can verify 200 hrs is max on the valve springs. Mine were broke all to hell at 170 hours....
Defineately agree, had triple 500 in my last boat,98 outerlimits, checked valve springs around 150 hours found 1 broken replaced them all, checked again at 300 hours again found one broken, replaced them all again. If you go with the 200 hour boat, change the valve springs, not hard to do and will be money well spent.
hardcore is offline
Old 04-13-2015 | 03:50 PM
why not buy a 35 with 502s or 496HOs? trouble free boating for a couple of miles less.
boatnt is offline
Old 04-13-2015 | 11:14 PM
Both EFI boats are 03s and the carbureted one is a 2000
fordf350 is offline
Old 04-13-2015 | 11:18 PM
[QUOTE=boatnt;4291686]why not buy a 35 with 502s or 496HOs? trouble free boating for a couple of miles less.
I have not ruled out 496s or 502s. Black Mercurys are just fine and every boat I own has a Mercury on it or in it. The 454 EFIs in my 29 are and have been great. But I want any added performance the 500s provide and if the one in Canada that had 500s with 671 blowers on it was still available I would be going there first. He sold it the day I got my passport.
fordf350 is offline
Old 04-13-2015 | 11:37 PM
The carburated 500's are the ones that had the early problems with valve springs. The 500 efi did not have these problems. This is not to say that you can ignore routine maintenance but they didn't break springs like the hp 500's did.
billpor930 is offline
