Engine synchronization on hp 500's >
Old 04-13-2015 | 05:40 PM
Originally Posted by BUP
The jist is we use a digital rpm gauge, and ground out spark at each cylinder one by one and look for rpm drop - if no rpm drop that is your problem cylinder. We use 3 inch vacuum hose lead that connected to the distrib terminals and spark leads and ground each by a grounded test lite.
Ah, good plan!
Cole2534 is offline
Old 04-13-2015 | 05:42 PM
Yes sir. Thats how I used to do it back in the day when I worked as a tech. Very common procedure on the old HEI ignitions. As well as turning the lights off, and spraying windex on the plug wires looking for arcs.
MILD THUNDER is offline
Old 04-13-2015 | 06:35 PM
This was the fun days.. And actually still good knowledge that works to date that seems to be long forgotten at times. Thumbs up!
getrdunn is offline
Old 04-13-2015 | 08:18 PM
BUP
We still do a power balance testing on MPI engines but the kicker is you have to catch any RPM drop very quickly because the IAC will over compensate pretty fast for the drop then help pick the rpms back up ( inputs to ECM - ECM adjusts RPM's) . Another reason why I like the digital rpm gauge.
BUP is offline
Old 05-12-2015 | 07:45 PM
You ever get this figured out?
richanton is offline
Old 05-14-2015 | 12:14 PM
I got everything set perfect timing wise. Went through the carb on the slow motor.....changed cap and rotors on both and it's still that way. Going to look closer at the linkage and WOT... not sure how that could have changed but.....
kennyo is offline
Old 05-15-2015 | 09:23 PM
How does the slower engine sound compared to the other? Should be a noticeable sounds difference at idle if it is dropping a cylinder on those motors.
Powerquest230 is offline
Old 05-19-2015 | 09:14 AM
They both sound good. No miss. The linkage looks good... going to swap props next and see if it goes with the prop. Like I said. I put it up perfect last fall... Got me puzzled.
kennyo is offline
