rocker arm stud diflection >
Old 04-19-2015 | 06:15 PM
  #51
Originally Posted by Black Baja
Having seen a few bad sets and warned by a few who build motors and heads for a living of the pitfalls. It was recommended to me by someone who builds some of the fastest heads in the world that if weight wasn't a concern the race series head was the way to go. For those reasons I have steered clear of them.
first you claimed they have geomitry problems,than they are too lite,now some HEAD BUILDER told you to steer clear of them,do you ever run out of bullchit?
mike tkach is offline
Old 04-19-2015 | 06:16 PM
  #52
Originally Posted by abones
Thank You MT I was waiting to see how long it took before someone stated the obvious.
I'm just waiting for someone to bring up AFR's exhaust port.
MILD THUNDER is offline
  #53
What I meant by the geometry problem was a generalized statement not directed towards a pro 1 head. But a BBC in general.
Black Baja is offline
Old 04-19-2015 | 06:20 PM
  #54
You should see the geometry on some of AFR"s bbc heads. Particularly the intake rocker stud to valve distance. Nothing a .090 backset rocker arm couldnt help though. Now, with a scorpion rocker or comp rocker, perfect pushrod length, the roller tip would be nearly on the retainer, rather than the valve stem. But supposedly they fixed that.
Old 04-19-2015 | 06:21 PM
  #55
Originally Posted by Tinkerer
I can't find anything wrong with the head. The lock nuts are all the exact same height ( straight edge straight ) The boss is perfect. I don't for the life of me know why there is this pattern on the bottom of the valve cover. Looking at the cover that is a low spot in the face of the cover. There are other marks on the cover but none as pronounced as this one. Nothing seams broken here.
i have seen the stock covers get rubbed like that a few times due to the difference in the base circle of the cam and geomitry issues due to improper setup.im not saying that is your deal,it is hard to tell from the pictures.maybe you should throw the pro1 heads away as bb claims they are all junk,lol.or add a vc gasket to raise the cover a little,i have seen it done with good results.
Old 04-19-2015 | 06:25 PM
  #56
Tink, what rocker studs are in those heads? Just wondering why the intake poly set screws, are sunk quite a bit down in the lock, where the exhaust, not so much. How much thread engagement did you have on those intake studs???
Old 04-19-2015 | 06:32 PM
  #57
bb,read post 20,i believe it is your post,than tell me you were generilizing the bbc,and not the dart head.again more of your bullchit.please stop!
Old 04-19-2015 | 07:06 PM
  #58
Obviously you have no reading comprehension. Please read and re-read post #20 and maybe you will get it on your own. I may have some bullchit coming out of my mouth but obviously you have diarrhea of the brain.
Old 04-19-2015 | 07:17 PM
  #59
I <3 forum wars....
so what's up with the afr exhaust ports :-P
Kyain is offline
Old 04-19-2015 | 07:20 PM
  #60
SB
I read Post #20 and you can take i both ways.
I took it first as any motor with rocker arms has a geometry problem.
But, re reading it, I can see it the other way.
So, your both right and wrong.
Miscommunication thru typing at it's finest.
Move on.
SB is offline
