Tranny vs bravo boats >
Old 04-22-2015 | 07:47 PM
F-2 Speedy's Avatar
Default Tranny vs bravo boats
Are most of you guys with tranny boat's running flex plates or flywheels, I'm running into an issue converting from a bravo coupler to a pressure plate style. I'm needing to open up the center ring of the flywheel 1.5 inches to accommodate the new coupler with its riveted on spring plate, the bravo coupler is flat on the back where this one is raised about an 1/8 inch. I know the fix just wondering what u guys are running. Does a marine flywheel have a larger center than a car application,
F-2 Speedy is offline
Old 04-22-2015 | 08:03 PM
Running flywheels, with a damper plate that bolts to the flywheel.
http://teaguecustommarine.com/em0011/drive-plate.html
MILD THUNDER is offline
Old 04-22-2015 | 08:43 PM
Never had an issue, bolted several different style damper plates to the flywheels.
Unlimited jd is offline
Old 04-22-2015 | 09:07 PM
F-2 Speedy's Avatar
Here's the issue, is this not the correct one ?? thanks for the reply's guy's
Attached Thumbnails Tranny vs bravo boats-img_0228.jpg   Tranny vs bravo boats-img_0229.jpg
Old 04-22-2015 | 09:24 PM
OK, I see your problem. Some machining may be necessary with that particular plate. Call these guys . they will explain. They make them.
http://www.innovationeng.com/drivpla.htm
Old 04-22-2015 | 09:40 PM
F-2 Speedy's Avatar
Thanks, Mild............ seems I'm spinning why wheels, getting this thing moving forward,
Old 04-22-2015 | 09:47 PM
I vaguely remember that certain damper (drive plates) required machining of the flywheel. Mainly the big heavy duty ones from what I recall. Its been a while since I fooled with that.
Your typical cheap trs style plate won't have those issues. Those aren't rated for big power. Mine, are rated for 1000ft lbs, pretty much the ones merc supplied with the #6 package .then there are the ones that take even more power, and may require machining of the flywheel.
Old 04-23-2015 | 04:44 AM
Full Force's Avatar
Looks like a billet aftermarket flywheel, not a typical factory one, that will play a role in it I think....also check starter ring I think the Bravo sits on the inside of the flywheel where a trans flywheel the ring is on outside of it.... that I kn ow is different from Bravo to Trans...
Full Force is offline
Old 04-23-2015 | 06:18 AM
i guess the obvious..."you got the coupler on backwards" doesn't apply here? and i would rather settle for bravo drives. trannys look funny in a bikini...
dereknkathy is offline
Old 04-23-2015 | 06:24 AM
Second pic is of a typical TRS driveplate. Mercury used these on transmission boats up to 420HP engines. Anything 465HP and over, got the HD drive plate (first pic), up to 900sc applications...and yes, I have seen the TRS plates explode. A buddy of mine exploded one, and when it blew apart, it put a hole in his bellhousing!
Attached Thumbnails Tranny vs bravo boats-damper-plate-7.4l454cit-14-flywheel_1281.jpg   Tranny vs bravo boats-816618.jpg
