Change plugs after fogging? >
Old 04-23-2015 | 08:21 PM
Default Change plugs after fogging?
What's the consensus? Do you change to new plugs after you fog for winter? I winterized my 496 HO per the Merc "soup" mixture and upon checking the plugs today, the porcelain is oil covered and very dark. Coming from carb'd engines where I used fogging oil into the intake, I always replaced with new plugs in the spring and kept a set of plugs to put in just for fogging.
Was thinking the FI mix would not turn the plugs as black as the carb method does. I'm going to throw in a new set and keep the spares for fogging.
Ryan00TJ is offline
Old 04-23-2015 | 08:31 PM
I fog till it stalls and won't even kick.starts it up in the spring and runs fine all season.just saying
sutphen 30 is online now
Old 04-23-2015 | 09:23 PM
Go run the dog shxt out it for 10 minutes. They'll look the same before you fogged.
getrdunn is offline
Old 04-23-2015 | 09:35 PM
BUP
Mec is way off base with the 10 to 1 gas to oil mix. Volvo and even Indmar recommend 50 to 1.
IMO depending on area 40 to 1 to 60 to 1 works the best. I really soup mix at 40 to 1 or 50 to 1 nowadays.
You really have to do the soup mix no matter of the app even carb engines this way because of the fuel offerings even if it E - 0 in your fuel system as well.
Read post 18 and 19 in this link
http://www.offshoreonly.com/forums/d...k-63mph-2.html
BUP is offline
