Valve Cover Breathers:  What Works? >
Old 05-01-2015, 01:12 PM
Originally Posted by Gimme Fuel
Yea, the only one that gets any mist out of it is the rear.
Can you swap it to the rear? One of my valve covers had two holes. The fill cap and breather could be swapped to either. It looks a little funky with both up front. But it is what it is.
From the looks of your pics. It shouldn't be a problem to swap them.
Black Baja is offline
Old 05-01-2015, 01:24 PM
So that is something like a victor intake with injector ports? There is probably a manifold vac port behind throttle body. Run a pcv valve from rear breather port to that vac port. Will virtually disappear behind throttle body.
dereknkathy is offline
Old 05-01-2015, 03:20 PM
Last year I switched from the KN style breathers with Merc finned valve covers, to the angle cut Teague style valve covers, with tall stack style breathers.
I ended up having to mount the breathers in the rear, because in front, they would not clear my stellings green headers. I did not have any oil blowing out of them last summer while mounted in the rear.
Prior to that, with the merc finned valve covers, and KN breathers, the way it was setup, was one breather in front on odd bank, one breather in back, on the even bank. I did get a slight mist of oil from both of them equally after a hard run.
Attached Thumbnails Valve Cover Breathers:  What Works?-mymotors.jpg
MILD THUNDER is offline
Old 05-01-2015, 05:10 PM
I removed my intake drilled and tapped a hole basically between the dizzy and carb. Believe it was 3/8 pipe. Installed a 3" or so pipe and coupled it to a PCV valve and to manifold vacuum. In this case to the rear of the carb. Then installed breathers to the front of each valve cover. That way it had to pull air through the engine as well as possible. Worked great. Also a valley baffle can be installed which can depend on valve lift.
turbo2256b is offline
Old 05-01-2015, 05:49 PM
Is there any way to get a baffle under the K&N filters? If not, you can raise them up some. You need time for the oil to settle out of suspension. Also, once those filters get soaked with oil, they stop breathing that good. This allows the engine to build some crankcase pressure, which in turn wants to force more oil out of the filters.
A puke tank is the best option. If you go that route, try to run the hoses uphill all the way to the tank. This will allow any oil to drain back into the valve cover once it comes out of suspension.
Eddie
Young Performance is offline
Old 05-01-2015, 10:46 PM
Received 4,326 Likes on 1,241 Posts
I hope my new set up finally stops the damn mess once and for all.
So tired of wiping up oil and putting socks over breathers.
ICDEDPPL is offline
Old 05-07-2015, 06:54 AM
Thanks guys. I found a decent puke tank with dual 1/2" NPT inlets but have not ordered it yet. I plan on running 5/8" line and hose barbs, do you think that is sufficient diameter hoses for the breathers on a 540? Or should I look for something larger?
ICDEDPPL, that is a beautiful setup!
Gimme Fuel is offline
Old 05-07-2015, 07:08 AM
35fountain's Avatar
I put 2 of these in my boat. One for each engine 1/2 ports
http://www.ebay.com/itm/Polished-Alu...825842&vxp=mtr
35fountain is offline
Old 05-07-2015, 08:45 AM
That is the same one I was considering. Glad to have some feedback on it. Thanks.
Old 10-09-2015, 11:04 AM
Ran-Dom 32's Avatar
looking to add catch cans, any pics of them mounted? just looking for ideas..
Ran-Dom 32 is offline
