Cmi air cylinders >
Cmi air cylinders
Cmi air cylinders
Old 05-05-2015 | 04:05 PM
35fountain's Avatar
Default Cmi air cylinders
Just purchased 4 used CMI 13365 silencers...and found out the air cylinders are defective.. I tried looking online for a replacement without going to the manufacturer @ 175-200 each
Anyone know of an aftermarket replacement??
35fountain is offline
Old 05-05-2015 | 04:15 PM
Fix the ones you have. Take a little dish soap & work it into the cylinders. Work the cylinders back and forth. then hook them up to air and work them
Bawana is offline
Old 05-05-2015 | 06:20 PM
35fountain's Avatar
The problem with the cylinders is a few leak out of the vent port and 2 others have cracks in the plastic end caps. Apparently the guy who owned these before tightened the brass fittings into the plastic to far and cracked them. Now when you tighten them the brass fitting hits the shaft. What a poor design for 200.00 a air cylinder. Should have been made out of all stainless.
Old 05-06-2015 | 10:28 AM
I have a 4 used CMI 13305 4 1/2 silencers. All cylinders worked perfectly when I removed them from the boat. I'll sell them for $400 plus shipping.
JMS322 is offline
Old 05-07-2015 | 05:43 AM
35fountain's Avatar
Your talking about the air cylinders only ???
Old 05-07-2015 | 07:16 AM
Pm me your number. We'll talk
JMS322 is offline
