Springs pressures and valvetrain life >
Old 05-08-2015 | 11:33 PM
Mike @ High Flow likes to run most set ups over 200. Gotta be a reason.
ICDEDPPL is offline
Old 05-09-2015 | 03:05 PM
Just finished running the valve lash. After two full boating seasons, we did not need to change the lash on a single valve. We could have checked the spring pressure, but we decided to wait until next year. Checking the lash on both engines took about 90 min, the KEPP valve cover system a a big time saver. If you run hydraulic lifters, how do you know if your valve train is wearing before you see broken parts?
BenPerfected is offline
Old 05-09-2015 | 03:52 PM
If it's been setup on a spintron I would be equally concerned of the spring going away as the lash. How much lift is the cam in these combinations?
Black Baja is offline
Old 05-09-2015 | 06:51 PM
So, solids are getting a little positive press these days. what about solid rollers on a hyd roller cam?
dereknkathy is offline
Old 05-09-2015 | 07:53 PM
i know several people that have been doing that for years with great results.
mike tkach is offline
Old 05-09-2015 | 11:18 PM
simple. you hear the broken parts. then you remove the valve cover. THEN you see the broken parts...
Old 05-10-2015 | 05:43 AM
vintage chromoly's Avatar
Not sure if you're being sarcastic but........
The idea is that with a solid cam, you can check lash and if something is going south, you can identify that there is a problem before it all comes unglued.
A hydraulic cam will mask small dimensional changes and the end user will not know until it's too late.
Again, maybe you were being coy?
vintage chromoly is offline
Old 05-10-2015 | 06:41 AM
You can do the same with a hydraulic cam. You would basically be checking the preload.
Old 05-10-2015 | 11:10 AM
So if i want to swap my noisy Morel 4603 hydrolic to any other mecanic lifter i can use my actual hydrolic cam and also my actual valve spring?
supermx96 is offline
Old 05-10-2015 | 11:20 AM
I suspect that's a case by case kind of decision where you would need to know the cam's specifics to determine for sure.
Cole2534 is offline
