BBC Engine missing side caps?
I have seen several people get lucky with replacing the freeze plug. If they actually winterize the boat but some water stays in the side of the block with to much sand (mostly because they power onto the beach with motor running), then it will push out the freeze plug. I am always very skeptical, but even last spring one of guys down the street stopped by and asked why he found this strange plug in the bottom of his bilge. He went to the auto parts store and bought a rubber freeze plug and boated all season with it. Where we boat we have a lot of sandy beaches, so if the isn't your case and winterization wasn't performed, your block is most likely cracked.
Post 25 is correct and FWIW Mercruiser calls and lists them as expansion plugs. Just saying, everyone calls them freeze plugs (on the side of block) especially for the marine side of things..
