oil temp
Old 05-11-2015 | 04:03 PM
Default oil temp
where should I put my oil temp sensor, pan?
bigbird241 is offline
Old 05-11-2015 | 04:25 PM
vintage chromoly's Avatar
Pan
vintage chromoly is offline
Old 05-11-2015 | 05:33 PM
Rookie's Avatar
Debatable, some people like to know the temp of the oil in the pan. While others would like to know the temp of the oil being delivered to the bearings after the cooler. A simple toggle switch and 2 senders and you can toggle between both.
Rookie is offline
Old 05-11-2015 | 07:11 PM
This is really the only way to know what's going on inside the motor.
Black Baja is offline
Old 05-11-2015 | 07:21 PM
Tinkerer's Avatar
That's a good idea. I have mine in the remote oil filter housing which should be the same as the pan temp, I will have to see about installing one in the circuit after the oil cooler.
Tinkerer is offline
Old 05-12-2015 | 06:55 AM
have mine in filter mount, works fine
ezstriper is offline
Old 05-12-2015 | 08:34 AM
What should oil temp/ water temp be ??
Bajadave04 is offline
Old 05-12-2015 | 10:23 AM
Good idea.
Cole2534 is offline
Old 05-12-2015 | 12:54 PM
don't forget to run a ground back to the block from filter mount or gauge may not read, 210 is where I run now with thermostat
Old 05-12-2015 | 12:58 PM
ROB FREEMAN's Avatar
215 to 220 warm enough to boil off condensation .. t stats so i rarely see much water temp .. good oil thermastat to ensure good oil temps is key i was told by pfaff engines ..
ROB FREEMAN is offline
