hp500 distributor fit on 500efi >
Old 05-11-2015 | 07:53 PM
Registered User
Default hp500 distributor fit on 500efi
is it the same? will it work?
Thanks for the help in advance
the blue blur is offline
Old 05-11-2015 | 09:27 PM
BUP
100 % no - not even the same app - 500 EFi is Delco HEI with module - IC and the ECM reads this.
500 carb distributor set up thru out - T bolt IV & V.that uses the ignition sensor assembly- oil filled coil
The coils used are not even the same, the distributor caps not even same, Merc part numbers not even close to being same and so on and so for the jist of it..
BUP is offline
