Cleaning under trailer bunks >
Old 05-18-2015 | 08:37 AM
Default Cleaning under trailer bunks
How do you clean your bottom where the boat sits on the bunks? If you do how do you raise boat off trailer?
Hotdog1922 is offline
Old 05-18-2015 | 12:14 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Jack the entire boat/trailer up in the air 6 inches.
Place 3 supports under the boat, keel, and back two corners...
...made out of SOLID cinder blocks and 2" thick wood between boat and cinder blocks.
Then lower the trailer away from the boat.
Reverse process when done.
Sydwayz is offline
Old 05-19-2015 | 07:54 AM
You can also try. First lower the tongue jack as low as it can thus raising the transon. Place wood blocks under transom. Raise tongue then all the way up and block the front. Then bring trailer jack back down.
92nsx is offline
Old 05-20-2015 | 05:40 AM
Another option, boat to a local marina with rack storage and see if they will put the boat on a work rack. It will likely be less $ and for sure less hassle and safer.
BenPerfected is offline
