How to get a little heat with crossovers...?
#61
That's fine.I have ran into that too. Southern builder sends motor up here. Engine has cooling issues. They get perplexed. In the middle of summer warmer water they work fine.
Not everyone can possibly know everything.
When you are a manufacturer, you have to test in all conditions.
#62
as a side note .. when paul pfaff put my pakages together .. fully rigged ready to drop . i talked about water temp .. and i was told as long as youre running a oil stat system witch brings oil temps to operating range there is no need ? was he correct . they are a big builder of high end motors in southern cal ... told him i boat in cooler waters than them
#63
True...but getting oil temp up is killer tough incold water. Even with t-stats. 5 million hrs after cruising for a bit,you get good oil temp. Then you come off plane to take a break. Your oil temps plummet back to cold.Now you want to take off again,but noooooooooo...you gotta wait for another 5million hrs.
If you don't let the temps get up your oil gets 'soggy'.
Again, this is for some of us that boat, at times. in very cold water. But, some people around here only boat end of June thru August, so,they are all set.
I here timeandtime again around here,even you today or yesterday, I don't care if I lose 10-15hp or not make an extra 10-15hp.
Well, the recirc pump doesn'ttake that much power to spin under 6k, so why do many people spend $$$ on cross overs that don't need them.
It's like the guy who buys a $300 cast steel crank instead of a $700 forged crank, but has $300 valve covers and sends them out to a custom painter.
FF - not singling you out cause you already had these.
Just making a point with what I see in this performanceboat worldand trying to makesomesense. LOL.
#64
My space bar is not workingto well. LOL.
#65
I know some people who got rid of their circ pump and went with a crossover because it "cleans up" the front of the engine and looks nicer. You have to have that bling under the hatch, ya know!
#66
my engines build oil temp fairly fast .. 5 minutes maybe .. i also run teague offshore coolers ,, bounce up to 3 k, let em warm up, loosen up, n then its go time .. i can wait 5 minutes just listning to that cam thump pretty noises to my ears .. besides people on shore love to hear them too .. lol nothing like big cammed idling big blocks ....
#67
Put stats 140 stats in, ran on the hose and they will not open, up to 180 and still not open..the bypass hose is dumping cold water on stat keeping it from opening... my stainless marine housings do not have that diverter in there to stop that....
I now have loose clearances in lifter bores and guides, might just run the way its been for years.....
I just got engines in and running good Sunday, no time to hunt down and install circ pumps....I did order water restrictors may play with that now that I wave water pressure gauges installed...
#68
You do atleast have some holes dilled in the oute edge of the tstat's right ? And a way to gauge water psi ?
#69
