Cam intensity question >
Old 05-31-2015 | 06:22 AM
vintage chromoly's Avatar
Just bought my cam/valvetrain a few months back.
55mm solid roller
Isky tool room springs.
Jesel rocker arms
Morel lifter (.904 with an .810 wheel)
Closed psi- 195
Open psi-540
Cam is 720 lift and mid 200's @.050 ( I can't remember the exact duration but it's in the 250 range)
vintage chromoly is offline
Old 05-31-2015 | 08:20 AM
Originally Posted by SB
Did a quick search, and Here's an old thread with Harold Brookshire and Mike Jones responding to someone asking about IR cams.
Jones does mention use in HR's
http://speedtalk.com/forum/viewtopic.php?t=8711
and in the same year,,Isky says this.
http://www.iskycams.com/tech-tips-2000.html#2007
sutphen 30 is offline
Old 05-31-2015 | 08:26 AM
heres an idea,,stop using drag race cams in a marine motor.unless your gonna run your engine 7-10 secs at a time,then your ok.
you guys can do the math,top sportsman sbc,(sbx) 1.1" lift,425lbs seat,1195lbs over the nose,,springs are good for 1 season ~12 events.aluminum rods are good for 2 seasons.And I check the springs every week on the car.
Old 05-31-2015 | 08:42 AM
SB
And a little earlier Isky said this: .
http://www.iskycams.com/tech-tips-2000.html#2003
SB is offline
Old 05-31-2015 | 09:02 AM
The problem is, most guys don't know the difference between a drag race cam, or an endurance cam profile. The average guy looks at a "marine" cam, as one that has no duration, and can be run with wet manifolds, as being the only difference between a BBC "boat" cam, and a 1/4 mile cam. So, they look at the duration numbers, and LSA, and think its all good for a boat.
It be nice to see cam cards from cam companies putting duration numbers other than at .050 and .004 on their specs.
Camshaft intensity is a measurement term coined by Harvey Crane to compare ramp characteristics of camshafts.
• Hydraulic Intensity is the difference between the .004 duration and the .050 duration.
• Minor intensity is the difference between the .010 duration and the .050 duration.
• Major intensity is the difference between the .020 duration and the .050 duration
Lower numbers indicate more radical profiles but too low can be too radical and lead to noisy valve train and even to broken parts
MILD THUNDER is offline
Originally Posted by Bawana
Joe. who is running 600lbs on hydraulic lifters? I was told anything over 500lbs will sink the best of them. I was always told that; more then needed spring pressure = short valve train life, and will rob power.
Exactly why I didn't jump on the higher pressure bandwagon when replacing the springs on my 525. Mercury's choice has worked fine.
thirdchildhood is offline
Old 05-31-2015 | 09:07 AM
Looking thru comp cams master lobe catalog, they have specific marine lobes. These are their basic marine camshaft lobe profiles....for a cam duration like mine for example of 236*, it has a lobe lift of .357. and .607 valve lift with 1.7 rocker.
XTREME MARINE™ HYDRAULIC ROLLERS
These profiles use the same design techniques of the baseline Xtreme Energy™Hydraulic Rollers but have been opti-mized to increase power and durability when run at steady rpm for extended periods of time. Specifically designed
for big blocks with heavier valve train components
1.800.999.0853
HYDRAULIC ROLLER
HYDRAULIC ROLLER
16
LOBE RATED DURATION IN LOBE TAPPET LIFT @ THEORETICAL VALVE LIFT
NUMBER DURATION DEGREES LIFT TDC @
“0” LASH ROCKER ARM RATIO
CAMSHAFT TYPE
@ .050” @ .200” 106° 110° 1.5 1.6 1.7
3033 264 212 135 .341 .050 .040 .512 .546 .580
3034 270 218 141 .347 .059 .048 .521 .555 .590
3035 276 224 147 .353 .069 .056 .530 .565 .600
3036 282 230 152 .355 .080 .066 .533 .568 .604
3037 288 236 158 .357 .091 .076 .536 .571 .607
3038 294 242 163 .360 .102 .087 .540 .576 .612
3039 300 248 169 .362 .114 .098 .543 .579 .615
Old 05-31-2015 | 09:21 AM
Then their is their "high lift" version of their marine hydraulic rollers. A 236* lobe for their high lift version, has a .360 lobe lift, with .612 at the valve with 1.7. While I certainly don't think comp cams is god, they aren't new to the cam business, marine, endurance racing, etc. They have quite a bit of a knowledge base on camshaft lobes. Also, when looking thru cranes literature, I have not seen anything with a "marine" useage or endurance useage, with anything near .680-.700 lift with a 1.7 rocker, even on the longer duration stuff.
XTREME MARINE™ HYDRAULIC ROLLERS - HIGH LIFT
These have the same ramp designs as the lower lift Xtreme Marine
designs but have higher lift to enhance power
output with cylinder head and engine modifications.
CAMSHAFT TYPE
3473 290 234 152 .360 .081 .068 .540 .576 .612
3474 292 236 154 .360 .085 .071 .540 .576 .612
3410 294 238 154 .350 .088 .075 .525 .560 .595
3475 294 238 156 .360 .088 .075 .540 .576 .612
3376 296 240 157 .360 .092 .078 .540 .576 .612
3411 300 244 159 .350 .099 .085 .525 .560 .595
3370 304 248 167 .380 .107 .092 .570 .608 .646
3377 306 250 166 .360 .111 .096 .540 .576 .612
3371 308 254 171 .380 .119 .103 .570 .608 .646
3372 314 258 175 .380 .126 .111 .570 .608 .646
3373 318 262 179 .380 .134 .118 .570 .608 .646
3374 322 266 182 .380 .142 .126 .570 .608 .646
3375 326 270 186 .380 .149 .134 .570 .608 .646
3447 330 274 190 .380 .157 .141 .570 .608 .64
Old 05-31-2015 | 09:31 AM
Also for those who have a Dyno-Sim program plug in a more aggressive cam profile, see what the HP/TQ gain might be and decide if the gain is worth the reliability issues that are associated with the profile when used for marine long term usage! I'll bet it is not worth the grief.
abones is offline
Old 05-31-2015 | 09:55 AM
Very true. From my experience with my engines, and a few friends engines, that have had lobe lifts of .370 range or less, with duration numbers of 235ish to 245ish, have seen good life from the valvetrains. Not talking 1000 hours, but 200-300 hours isnt out of the question, with moderate spring pressures. What concerns me, is a few buddies who've got custom cams for their marine engines, that have similar duration numbers, std bbc journal, std .842 lifters, but are sporting .400-.410 lobes. The cam guy they use doesnt provide them with duration numbers at .200 on their cam spec sheets.
I guess time will tell how their valvetrain holds up, and if the extra little bit of power, was worth it or not for them.
From the little I am learning on this stuff, is there is no getting around increasing lobe intensity increase, if duration doesnt grow with the lobe size. So, while most think they are simply adding valve lift, they are also increasing lobe aggressiveness..?...
Would it be wise to assume, keep gentle ramps, keep lobe lift down, run enough, but not excessive spring pressure, and make your power in other areas of the build, if long valvetrain life is what you want. Especially on forced induction marine stuff.
