98 502mag mpi surging
I have a 1985 Formula 302 with twin stock 1998 502mpi mags.
I am having trouble with the starboard engine after about 20min of running hard or cruise it begins to surge bouncing between 2000 and 3000 rpms. punching the throttle does nothing however pulling back to 2500rpm or under it stops surging and will run just fine. Running the throttles back up above 2500 will result in the surging. If shut down and wait for the engine to cool it takes another 20min for the issue to present itself again.
Normal engine temp
good oil pressure
92 octane fuel fresh and treated
fuel filters replaced in fall
tune up in fall plugs wires etc.
Fuel issue?
IDEAS?
Normal engine temp
good oil pressure
Fuel issue?
IDEAS?
I doubt its the IAC as that has predominant affects during the idle regime. It could possibly be the TPS sensor gets whacky when warm but that is a stretch. Swap sensors between motors and see the the problem goes to the other motor.
The MAP sensor could be another possible culprit, but again that is likely a stretch.
Fuel issue? Just thinking out loud.
what Im saying is put a gauge on it and watch it as it starts surging, is that what you did, it has the smell of vapor lock to me, u turn it off, cools down, runs fine, till it heats back up, or did I miss something
Sure sounds like fuel supply issue to me too.
Biggus maybe correct, but the near 100+ EST modules I've seen go bad, typically will not restart right after turned off after a run.
I'd also check the fuel psi right when it is doing this.
Fuel deliver problem of some sort or possible TPS sensor
The hotter the fuel pump can get the worst they get. Run a temp gun on the electric fuel pump and record temps.
Anyone scan this engine ?
any details how you tested fuel pressure ? and what was the readings @ idle - 1500 rpms - 2000 rpms - 2500 rpms and 3000 rpms ?
