stepped hull and props >
Old 09-10-2002 | 11:25 AM
Whitey's Avatar
Default stepped hull and props
I have a single stepped hull and am currently running a 3 blade prop turning props inboard. What are the other members doing with the stepped hulls? When I turn the props outboard the steering gets so light that it is a challenge to control the boat. With the props turning inboard I can still control at high speeds. I believe that the problem has to do with natural lift produced by the stepped hull. Any other insights would be helpful. What are prop suggestions? Thanks Dwight
Whitey is offline
Old 09-10-2002 | 01:29 PM
Panther's Avatar
Frank's Marine Service
Default What kind of Hull
Whitey,
What kind of stepped hull? I have had most success with stepped hulls running 4blade props. It with more air under the boat, the 4blades hook up better. Either the bravo 1, or a hydamotive, but its a crap shoot. You'll never know until you try. It also depends on what you are looking for. The four blade may cruise a little faster but less top end. The step changes the whole equation though.
Panther is offline
Old 09-10-2002 | 02:06 PM
Whitey's Avatar
I have single step DDC hull, it is on a Challenger Offshore boat if that helps at all. Dwight.
Whitey is offline
Old 09-10-2002 | 02:12 PM
Panther's Avatar
Default try a 4 blade
Try a 4 blade prop. Either a hydromotive, or Bravo 1. You will need a slightly smaller pitch prop than you are running with your 3 blade props.
If you are running say a 25 pitch Mirage, you may need to run a 24, or 23 pitch hydromotive. Call up hydromotive, they will let you know what size you need to run.
The bravo 1 props seems to give excellent cruise speed.
I remember a while back I had a customer who wanted 4 blades on his non-step fountain. He said "Everybody says the fountains go faster with 4 blades". Well he was wrong. We hit 86 with the three blades, and 81 with the 4 blades. $1800 later he learned the hard way. In doing my own research I found out that the 4 blade props run best on the Fountains with step bottoms. He got shafted by his friends!!!
See if you can borrow or set up an exchange with someone before you buy anything. I don't know how your particular hull will react.
Panther is offline
Old 09-10-2002 | 03:49 PM
Whitey's Avatar
Thanks for your input Panther, If anyone else has some input Iwould love to hear it. thanks Dwight
Whitey is offline
Old 09-10-2002 | 08:18 PM
Whitey's Avatar
There has to be some other stepped hull twin engine people out there? What s you set up? Dwight
Whitey is offline
Old 09-10-2002 | 08:52 PM
BillR's Avatar
OSO Moderator
I'm runnin Bravo 1 4 blades spinning inward. Three blades don't work well on stepped hulls. The prop is always in / out of the water and in airated water. The bravo 4 blade hooks up better.
I had a single engine step hull, tried a 3 blade, and the results were total crap. The 4 blade carries the boat better, better holeshot and midrange punch and on my boat, MUCH better top speed.
Try a set of 4 blades, I think you'll find it to be money well spent.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 09-10-2002 | 09:28 PM
Whitey's Avatar
Thanks BillR for the help.
Whitey is offline
Old 09-10-2002 | 11:08 PM
candyman35's Avatar
Whitey,
Is the step similar to the large step on the 37' Active Thunders? I thought the Challenger hull was originally set up to run the Black Hawk drives.
I have a single step Fountain with the props spinning in. I have used Hydromotive props but still prefer the handling of the Bravo1's. If your hull is the large step you may want to post this question in the Active Thunder section. The same man designed both hulls.
Dan
candyman35 is offline
Old 09-10-2002 | 11:10 PM
Tinkerer's Avatar
You wana see if that thing can spin a set of labbed BRAVO 26's
Tinkerer is offline
