Questions on Engine Modification  xm270hr cam >
Old 06-04-2015 | 12:55 PM
LT5
Default Questions on Engine Modification xm270hr cam
Hi all. New here with some engine building questions. I currently have a 2002 caravelle interceptor. with a 350 and a corsa captain choice exhaust with Volvo sx drive. I am looking to have the vortec heads worked on with a 3 angle valve job and 2.02/1.6 valves put in & roller rockers; msd ignition. Also going to a comp cams xm270hr cam and performer rpm intake manifold. It currently has a 650 edelbrock carb that I plan on sticking with and stock Volvo exhaust manifolds. I have read where a person shouldn't use an open carb gasket but use one with the 4 openings, is this true??? Also will the factory fuel pump be sufficient? The factory engine is rated at 260 hp and I feel this should wake things up a bit. If anyone can answer my questions great or want to comment on this combination. I am looking to learn all I can Thank you-
LT5 is offline
Old 06-04-2015 | 04:24 PM
I would not worry about the exhaust gaskets.
In my estimation the stock fuel pump will be sufficient.
Trash is offline
