Holley EFI/DIS Conversion >
Old 06-10-2015, 05:46 AM
MER Performance's Avatar
RAGE,
I'm very happy to see a change in technical content here. I know; this threads subject is DIS, so I don't want to get off topic. I have 2 525EFI builds coming up, that are total rebuilds, I will be converting to the Holley HP EFI.
MER Performance is offline
Old 06-10-2015, 11:34 AM
BUP
following along so in post # 19 are you talking about Wilson as in
www.wilsonmanifolds.com
they use to be the ticket for a lot of drag cars using their intake manifolds
BUP is offline
DesertRage's Avatar
Thanks Guys!
MER, Your 525EFI conversion projects sound awesome. Will you be able to reuse the Merc cam and crank sensors? I looked at using those parts, but my block is a Dart (MK IV).
DesertRage is offline
Old 06-10-2015, 11:39 AM
DesertRage's Avatar
That's the place. They do a lot of EFI intake conversions.
Old 06-10-2015, 12:32 PM
Does the Holley ignition have the capabilities to run different timing in different cylinders?
Black Baja is offline
Old 06-10-2015, 12:52 PM
DesertRage's Avatar
If your running coil packs you can individually adv/retard ignition by .1 deg increments. You can also set individual cylinder fuel trim.
Old 06-10-2015, 01:00 PM
Wow! That's sweet. Can't tell you how many times I've had 1 or 2 trouble cylinders and the rest were fine. That system is where it's at...
Old 06-10-2015, 02:25 PM
Thanks Guys!
yes, if you had a cam sensor along with a crank sensor you could run sequential injection. (I have done some research on MEGA Squirt systems for my supercharged Mustang) that would clean up the bottom end even more. I am By far no expert on these HAHA
I know on the cars alot of guys run either 8 EGTs and or 8 wide band O2s. this is the easiest way to tune individual cylinders (either with timing or fuel) if you are having distribution issues in cylinders. So educate me as i am getting back into the boat scene from a 7 year absence. Where are you placing the wide band to collect the average Bank AFR? Is it just past the manifold on the riser? i am running IMCO power flow on my boat. (please don't judge they came with it).
The next question is how can you possibly check each cylinder to adjust your timing or fuel individually with wet Manifolds or headers?? each exhaust tube would need their own EGT or O2 sensor... Just Curious.
260Velocity is offline
Old 06-10-2015, 03:07 PM
All you do is make a spacer flange to go between the head and exhaust manifold and put your sensors right at each port.
Old 06-10-2015, 06:05 PM
Thats correct, or you can make a spacer plate, between head and header. I spoke with Dustin W about this, the wide bands are very expensive. I run a 8 pack wide band on the dyno and take an average at the collector using the Holley wide band , my 8 wide bands are in my dyno headers
.[ATTACH=CONFIG]542013[/ATTACH]
Attached Thumbnails Holley EFI/DIS Conversion-dsc00719.jpg
