Water pressure too high?
[QUOTE=minxguy;4315568]
Yes, That's normal.
. And they dump water over 1,500 rpms out of gear....
Are you saying the mercury valves dump water? I hope that is what you are saying because I installed one on a 454/385 hp and water was flowing out the side at an idle.
Thought the spring was bad, Took the valve off the boat, but if this is normal, I will reinstall.
Ken
Ken
Pic below... its the same thing on both sides at the rear of the manifold, into a Tee and dumped thru the transom
You are making this harder than it needs to be. Run a water pressure relief valve and be done with it. Holes in T-stat have nothing to do with pressure, I have two small holes in each t-stat and see 140-160 with a 140 t-stat.
I have a plastic merc valve with a small crack 1/4 long that sprayed a mist. I think it could be ground down and fixed. For $15 I will mail it to your door and you can try it. I even have pictures of the small crack. I run the ones from CP like you have shown. You need to get the pressure down, I never see over 25lbs on either engine at full throttle. And they dump water over 1,500 rpms out of gear....
Why did you change to a cross over?
[ATTACH=CONFIG]542010[/ATTACH]
Duly noted.... Ill do this for the hell of it to make sure tiny bit of water flow in front of block.
Thanks for the offer on the plastic valve... I went ahead and pulled the trigger on the brass relief valve, a 1/2 npt to 3/4 hose, and water dump.... Figured its not worth messing around with, esp after reading else where that the high water pressure can cause water to blow by some gaskets and cause milkshake oil??? Is this true?
Are you putting the valve on the intake manifold??
For most boating a WP gauge at the engine should suffice. When we redid the dash a few years ago, we added WP gauges and they are definitely useful on the West side of Lake Erie due to the amount of weed in the last few years. If our WP drops to less than 5 lbs(?) and the engine temps start to rise, it is time to stop and remove the weed in the sea strainers. We also have a high water temp sender in our total alarm system. Old school, but if the alarm buzzer goes off, you hunt the dash for the problem.
CP has a 1 1/4 inch slip on union with a 1/2 npt fitting in the center for mounting the press reg valve. This should go in the rubber hose that goes from sea pump outlet to the engine, preferably near the pump itself.
