Questions about big power >
Old 06-12-2015 | 01:23 AM
Originally Posted by 253
Yep,, the 1100's will burn more fuel than the 600's, heavier engines w weight of the blowers,, heavier #6 drives that require more power to run the same speed compared to XR'S..
Maybe I'm wrong but do the #6's create more drag in the water, less aeordynamic.? than XR's
Your Advantage Mid Cabin you have for sale is in Mint Cond. ,I have seen it.
SSM 6's are dry sumped and don't take that much hp to spin. 6's are more hydrodynamic than XR's.
I think the biggest consideration between the 2 should be repair/maint costs.
If an 1100hp/SSM6 boat has a problem and it could easily be a 30k+ problem.
Griff is offline
Old 06-12-2015 | 09:21 AM
not all #6 drives are dry sumped.
mike tkach is offline
Old 06-12-2015 | 10:14 AM
Off topic.... We're the #7 SSM wet or dry?
endeavor1 is offline
