-   -   What Engine Oil for Superchaged Engine? (https://www.offshoreonly.com/forums/general-q/327190-what-engine-oil-superchaged-engine.html)
UrbanDisturbance 06-10-2015 08:30 AM
What engine oil are you guys using for your supercharged engines?
SS930 06-10-2015 08:49 AM
Oh boy... :food-smiley-007:
SS930 06-10-2015 08:50 AM
BTW, I have had GL with VR1 50, Brad Penn 50, and even M1 15-50 and 20-50 (higher zinc).
minxguy 06-11-2015 06:29 AM
Why change then?
Ken
JRider 06-11-2015 08:35 AM
Originally Posted by minxguy (Post 4316117)
Why change then?
Ken
Reread the above posts
mike tkach 06-11-2015 12:03 PM
:food-smiley-007::food-smiley-007::food-smiley-007::food-smiley-007::food-smiley-007:add some salt in the oil,forget about zinc,it taste bad.
minxguy 06-11-2015 01:04 PM
You mean re-read the above post
Ken
SB 06-11-2015 01:08 PM
Depends on how much blowby you have.....lol....I see many SC motors with major oil smoke coming out of the breathers.
Knot 4 Me 06-11-2015 01:21 PM
Poor OP unwittingly steps onto an OSO Tech forum landmine...
Black Baja 06-11-2015 01:41 PM
Hey, easy now. Don't want to get the natives stirred up.
Black Baja 06-11-2015 01:43 PM
Renegade Racing oil 3000ppm
Valvoline Vr1 2100ppm
Both excellent oils. One things I don't like about VR1 is it's very difficult to see on the stick. Renegade is blue. They are both in the $4-5/ qt range.
MILD THUNDER 06-11-2015 04:19 PM
I'm sure you guys are referring to Icdedppl's video. FWIW, that is steam vapors from the moisture in the oil thanks to his leaking stellings headers, which have been replaced with stainless marine Gen III exhaust and 5'' dry tails.
While he did not, nor I did not, build his shortblocks, they leak down just fine, and since that video was taken there was nothing coming from the breathers besides a fine mist of oil, which is why even the best marine engine builders have puke tanks on their big power engines. That "smoke" you see, is NOT burning oil coming from breathers.
Either of you guys got any videos of your boats running? Seems like you guys always have alot to say, but nothing to show.
https://www.youtube.com/watch?v=U3zQvghTrf0
mike tkach 06-11-2015 04:26 PM
it,s pretty hard to video unfinished engines that are still on a engine stand.i hope someday we see the power results from them.
mike tkach 06-11-2015 04:34 PM
nice video,i see you have a fast afr setup.you know the results from that type of equipment is useless.just pull the plugs and read them.
MILD THUNDER 06-11-2015 04:39 PM
Fast widebands dont hold up well when you get them wet after you flip your boat over trying to do speed runs, or lose control of it and crash it into the rocks. Best bet is to keep the electronics to a minimum, and stick to plug reading . Plus, replacing all those pistons is fun when you melt them and blame it on your timing light accuracy.
mike tkach 06-11-2015 04:43 PM
^^^^^^very nice avatar^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
mike tkach 06-11-2015 04:48 PM
who did that?wait,i can probibally guess who,lol.
abones 06-11-2015 04:55 PM
Can that really Happen? Wow!
Now before this gets out of hand just look at where this thread got high jacked then PLEASE PLEASE shut up
mike tkach 06-11-2015 04:59 PM
tony,high jacking threads is the new thing now a days,lol.
abones 06-11-2015 05:03 PM
Its really too bad! this guy comes on to ask a question and now once again it turns to crap.. I don't understand the reason!
SB 06-11-2015 05:05 PM
I am not.
I would not point him out for anything for obvious reason's.
SB 06-11-2015 05:09 PM
Oil threads on all boards do this. Reason is, we all have opinions and none of us are oil engineeers nor testers.
I can say this, I only know of one person ever that had engine wear problems because of the oil he used, and this was a non oiling thru the pushrod 2k+ horsepower alcohol motor....having pushrod to rocker arm wear issues.
That said, I like VR1 for many engines and I like ROtella/Delo 15w40 for many other engines.
mike tkach 06-11-2015 05:16 PM
i almost feel sorry for the op.asking a oil related question around here is like playing with fire.imo,things like bearing clearance,hp level,max rpm and type of boat and intended use all contribute to what oil is best for the application.
MILD THUNDER 06-11-2015 05:19 PM
Nothing beats FRESH oil and a good maintenance schedule. fancy oil will do nothing for helping poor machine work, poor assembly, poor rigging, or a poor tune up.
I say go with a quality brand oil and filter, keep it clean, dont overheat it, dont overcool it and go have fun.
mike tkach 06-11-2015 05:27 PM
good advice!i have seen drain oil so nasty i wondered how the thing still ran.i won,t mention any names but i know a guy who had 150 hrs on his oil in his single engine boat and had no issues.after i scolded him he now changes oil and filter at 50 hrs,he just didn,t know any better.
ICDEDPPL 06-11-2015 05:35 PM
This is hard to beat .. I get em shipped right to my house.
http://www.walmart.com/ip/Mobil-1-15...ingMethod=p13n
SB 06-11-2015 05:38 PM
I was asked to come look at a boat and diagnose an idle issue...wouldn't stay idling when warmed up.
502MPI.
Found the typical regulator vac hose off. Okay, fixed that. Not much better.
Ticking noise from driver's side valve cover was slightly on my mind - enough to notice, but not to check out yet.
Checked oil. Very dark. Weird thing was that the oil was very thin....never really see oil that thin, even in cars that come to my shop for oil change and right off the street plenty hot.
Oil smelled like fuel, like fking big time ! Scary !
Had oil and my extractor in back of my truck, no filter, and did a quicky oil change cause it stunned me how thin from fuel this oil was.
Asked the guy when oil change was done. He said he pays his marina to do it every spring along with spark plugs and such.
Okay, new oil in (15w40 Rotella if you must know) and engine runs like there is no issue. Valve ticking noise is gone.
I come back later to change oil again and of course filter.
Guess fuking what ? Oil filter had never been changed since boat was new.Had the new markings on it from the manufacuturer. Guessing the oil neither.
Holy schit !
Thought the guy assumed marina was charging him for LOF and tune up, but he later showed me his spring put in water receipts. He was paying for them. Was itemized right in each bill.
WOW !!!!!!!!!!!!!!
Motor still stayed together after all that. Obviously I changed plugs/cap/rotor/fuel filter, and serviced everything shortly after.
Lost some faith there.
SB 06-11-2015 06:15 PM
Schweet !
SB 06-11-2015 06:30 PM
From Mobil's site and Product Data Sheet : http://mobil1racingstore.com/mo115sin.html
Mobil 1 15W-50
Back by popular demand, Mobil 1® 15W-50's high viscosity provides outstanding performance in high-revving, high-temperature conditions.
Mobil 1 15W-50 exceeds warranty requirements for gasoline engines where an API certified oil is specified. It meets: •API SM/SL
•Requirements for Diesel Powered Vehicles where an API CF or API CD is recommended
•Provides extra anti-wear additive for older vehicles
Mobil 1 15W-50 is formulated with SuperSyn, an extra-high viscosity synthetic fluid, plus extra anti-wear additive to provide extra protection for severe service applications such as towing, hauling and racing. Mobil 1 15W-50 is recommended for high performance vehicles including turbocharged and supercharged engines where a thicker oil film is desired.
Mobil 1 15W-50 is also recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required for newer generation vehicles. Mobil 1 15W-50 will also provide better anti-wear protection for higher valve spring tensions in certain racing engines.
Mobil 1™ 15W-50
Advanced Full Synthetic Engine Oil
Product Description
Mobil 1™ 15W-50 is an advanced full synthetic engine oil designed to help provide exceptional wear protection for a smooth driving experience. Mobil 1 15W-50 meets or exceeds the requirements of the industry and car manufacturers' standards required for high-performance turbo-charged, supercharged gasoline and diesel multi-valve fuel injected engines. Mobil 1 15W-50 is a winning, race-proven technology. It is especially suited for a wide variety of motorsports applications, towing, and other severe service situations. Mobil 1 15W-50 helps to provide outstanding engine oil performance and protection for the winning edge. Mobil 1 is the official motor oil of NASCAR.
Features and Potential Benefits
Mobil 1 15W-50 is made with a proprietary blend of ultra high performance synthetic basestocks fortified with a precisely balanced component system. Mobil 1 15W-50's heavier viscosity together with this high-performance component system helps to provide the ultimate in dynamic lubricant protection. This feature is supported, not only by meeting or exceeding the toughest industry performance standards, but also it is proven in gruelling racing applications. Key features and potential benefits include:
Features
Advantages and Potential Benefits
Advanced Full synthetic formula Helps prevent deposits and sludge build-up to enable long engine life Excellent overall lubrication and wear protection performance for many driving styles
Outstanding thermal and oxidation stability Outstanding performance during the maximum oil change interval recommended in a vehicle’s owners manual
Extra anti-wear additive Extra protection for severe service
Applications
Mobil 1 15W-50 is recommended for all types of vehicles, suitable for use in high-performance turbo-charged, supercharged gasoline and diesel multi-valve fuel injected engines found in passenger cars, light vans and trucks.
•Mobil 1 15W-50 is suitable extreme engine stress conditions, where conventional oil often may not perform.
•Mobil 1 15W-50 is not recommended for 2-Cycle or aviation engines, unless specifically approved by the manufacturer.
Specifications and Approvals
Mobil 1 15W-50 meets or exceeds the requirements of:
API SN, SM, SL, SJ
ACEA A3/B3
According to ExxonMobil, Mobil 1 15W-50 is of the following quality level:
API CF
Typical Properties
Mobil 1 15W-50
SAE Grade 15W-50
Viscosity @ 100ºC, cSt (ASTM D445) 18
Viscosity, @ 40ºC, cSt (ASTM D445) 125
Viscosity Index 160
Sulfated Ash, wt% (ASTM D874) 1.21
HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 4.5
Pour Point, ºC (ASTM D97) -39
Flash Point, ºC (ASTM D92) 232
Density @15.6º C g/ml ASTM D4052) 0.87
snapmorgan 06-11-2015 06:47 PM
Our oil engineer and tester got banned if you remember, when he couldn't get his one of a kind 496 built.
SB 06-11-2015 06:51 PM
Yup !
See, our oil threads have gotten better, not worse. We are making progress here !
MILD THUNDER 06-11-2015 06:57 PM
If youre interested his one of a kind 496 , it was for sale on facebook a couple weeks ago. Just needs finishing touches.
ICDEDPPL 06-11-2015 07:24 PM
So for all his genius he couldn`t even finish that engine? Now that`s funny
chrisf695 06-11-2015 09:55 PM
Funny because his engine is built.... He got banned because he spoke his mind about some Facebook stalking... But you probably already know All about that!
chrisf695 06-11-2015 09:58 PM
And his engine was never for sale for the record. Kinda hard to post up videos and progress when he is no longer a member here.
MILD THUNDER 06-11-2015 10:14 PM
2 Attachment(s)
:rolleyes:
chrisf695 06-11-2015 10:25 PM
Originally Posted by MILD THUNDER (Post 4316597)
:rolleyes:
Don't see anything about borgie anywhere on the add. But sounds like he's on your mind an awful lot even to this day. Kinda weird...
the deep 06-11-2015 10:31 PM
1 Attachment(s)
[ATTACH=CONFIG]542045[/ATTACH]
MILD THUNDER 06-11-2015 10:47 PM
If youre interested, I can email you the rest of the ad, with HIS phone number at the bottom. I won't post it here , although, i guess if its on facebook in a public group, its not really a secret.
If your here to defend your friend, please bring some hard facts next time, rather than call me a liar with what you think you know.
chrisf695 06-11-2015 10:59 PM
I don't need hard facts as his motor is 1. A gen V and always has been. 2. Was machined by Texas Joe in New River Arizona. 3. Has a 14 quart Dan Olson pan. 4.Holley DIS coils. But if it makes you feel better thinking this other engine is his, guess that's your business as he probably could care less and isn't even here to defend himself. Posting a cell number somehow proves who he is? Maybe you can use google to try and link the number to Borgie.... Again awefully obsessed with a guy who's been off of OSO for some time now. But that's your business.
Oh and I like Mobil 1 and RedLine fwiw getting back to the OP. As others have already stated, oil is kinda like a religion lol!
