On water hose 170deg im pretty sure
If I were you with the closest Merc service 3 hrs away, I would definitely buy a Rinda Scan Tool.
At this point its all guess work and a scan could pinpoint the problem. |
Originally Posted by baja h2x
(Post 4316563)
I pulled the jasper motor out when I bought due to water in oil! It had a super charged motor in it guy pulled it put a jasper create motor in. Didnt winterize it so I had manifolds tested they were good put new starter every thing you could think of is new. The long block was $6,000 then $$$$$$ from there. Don't get me wrong it runs great fires up first turn of the key. It just runs rich the back of the boat has a kinda grease film after being out and plugs look to be running rich.
So......you need to do some CSI work. WAG don't wok well even on stock motors. Less so on those that have had non OE changes made. |
Originally Posted by SB
(Post 4316663)
If he was running a SC and using the EFI system, chances are he had pogamming done. Depending on the SC he may have had lage injectors put in to....it's possible.
^^^ what SB said , if your running all the same stuff from the super charged engine, it should have a custom tune in the ECM and larger injectors, is it a mefi 2 or 3
Originally Posted by payuppsucker
(Post 4316676)
Will SWAG be any more effective?
Wait, SWAG-Scientific Wild Azz Guess
Its mefi 2
IMO, you may have multiple things to address, sooner or later its going to foul the plugs so bad that they wont refire, I would find someone you can trust and send them the ecm and see whats in it, or put up with it for the summer and do it later, but with out scanning it you don't know if its sensor related or not, such as a map
Mefi 2 is what I have
| All times are GMT -5. The time now is 05:33 PM. |
