Emi exhaust still reverting
That's not what I was referring to. I just did a search and didn't come up with anything. It seems to me Merc had a 1 way exhaust check valve, like a reed valve on 2 stroke motorcycles that mounted close to the riser.
Read this thread, have them make you a pair similar to these. These will not revert...
http://www.offshoreonly.com/forums/d...e-exhaust.html
you have used several sets of risers on the same manifolds. were they pressure tested? it is only reversion if it is not a leak. you say fairly mild cams but they came in these engines. it is a pain but doable to degree cams in the engine compartment. you gotta hog out center of degree wheel so balancer socket fits thru.
