Help with a newly rebuilt HP 500
We need info if the engine is healthy.
And then, if it is, we need exact info on what the engine was rebuilt with.
I can't tell you how many times I've tried to tune an engine that was supposedly 'off' that wasn't.
Just $$ and time wasted.
That's why we need the basics covered first.
If all checks out, and should be making more power, we can further help from there.
I am bringing it back to the engine builder tomorrow.Some of the new parts used are ss intake valves,inconel exhaust valves,srp forged pistons,hastings piston rings,cam motion cam,m77 connecting rod bearings,m77 main bearings,melling high volume oil pump.I went down in pitch because that was a starting point from the tech at hydromotive.I should be able to spin that prop at much higher rpm's then what i currently am doing.Hopefully i will have more answers tomorrow.Thanks for the input so far!
