Help with a newly rebuilt HP 500 >
Old 06-23-2015 | 01:46 PM
  #41
articfriends's Avatar
Who set timing and where is it at, has it been verified? cehck timing, plugs then compression and leakdown test. Maybe re-lash vaves. I just did almost identical build for a customer, 27 fountain, hp 500 efi, ran 74 speedo most time loaded, 76 speedo running light, hurt motor slightly and lost ring seal. Boat would barely run 72 speedo when he put it away, we pulled motor, Bob Madera spec'd a cam and springs, bored it .030 to 4.500, had heads bowl blended, monoblade throttle body and he's now running 79 speedo w 26 pitch LH at 5600. Runs 78 speedo with my rh labbed and cupped 26 bravo at 5500 in comparison. I think his speedo reads 2 or 3 mph fast too but in comparison, fwiw, Smitty
articfriends is offline
Old 06-23-2015 | 04:18 PM
  #42
I brought my boat back to the shop today.He said he was going to do a leak down test and then a water test,with a fuel pressure gauge hooked up to see if its getting enough fuel.I put my 24 pitch hydro on also to see if that helps.Hopefully i should know more by tomorrow afternoon.Thanks for all the input!!
tutzone is offline
Old 06-23-2015 | 04:21 PM
  #43
Smitty,The shop set the timing at 34 and will check it again before and after they do a water test tomorrow.
tutzone is offline
Old 06-23-2015 | 10:02 PM
  #44
I have never heard of cam motion . On many marine apps the hp500 cam is on the fringe unless you go stroker and or tubular. Or grind a custom from a marine guru who has memorized stock cam specs
airjunky is offline
Old 06-23-2015 | 10:09 PM
  #45
I thought Cam Motion was the company that guys like Bob M use to grind their custom spec'd cams. Could be wrong though - need to walk out and look at the box in my garage.
Budman II is offline
Old 06-23-2015 | 10:23 PM
  #46
SB
What do you mean on the fringe ?
Not a guru, but I have stock cams and many aftermarket cams memorized. Been doing this since my 1st Crower catalog u=in my early teens. Because of which I can never remember a family member's bday or anniversary. Too many importnat #'s in my head. Hah !
edit in: The descriptions next to each 'Beast' cam made me addicted to cams. Words like 'brutal acceleration' chnged my life. LOL.
SB is offline
Old 06-23-2015 | 10:28 PM
  #47
let me save you a trip.CORRECT.
mike tkach is offline
Old 06-24-2015 | 09:44 AM
  #48
donzi matt's Avatar
Kip Fabre of Cam Motion is known to be a genius with camshaft design. He has done some awesome things in the LSX world. He also grinds custom spec cams from other designers so just because it comes in a Cam Motion box does not necessarily mean it is a Cam Motion designed cam.
donzi matt is offline
Old 06-26-2015 | 08:28 AM
  #49
Any luck finding out your issue? Did u try the original prop?
endeavor1 is offline
